![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
Tire or Rim issue?
i was running horrible Bridgestone tires 185/60/15 that came on my stock TRD rims (15x5.5)...after i did some performance modification i changed my tires to Hankook V2 195/50/15 which is pretty good..i have dropped about 1 inch due to shorter tire wall..i am not stil confident through curves on high speed 100km+ (maybe im pissed because i lost to BMW 5 series during corners)...what is the issue? i have front tower strut and rear sway with performance strut and shock all the way around droped 1.5 inch..
do i need a wider width rims..? or better tires? Sent from my ASUS_Z00AD using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
#2 | |
![]() Drives: d4d Join Date: Sep 2010
#3 | |
a 195 on a 5.5" rim is going to be pulling the sides of the tire up. You need to move up to a 7" wide rim to maximize the tire contact patch.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
![]() I hope you actually mean curves!
sorry curves.....
#7 | |
![]() Sent from my SM-J700F using Tapatalk
| Tire rotation question | vasonline | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 02-15-2016 11:42 AM |
| Costco Tire Damage Issue | nkaufman | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 03-16-2015 07:48 PM |
| Tire Size and FE question | GMKing | Fuel Economy Forum | 8 | 09-01-2009 10:20 PM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 08:09 PM |
