Old 09-29-2016, 08:48 PM   #1
X-WingYaris
X-WingYaris's Avatar
Drives: Toyota
hard turn makes a jolt
I have a 2015 Yaris Le with only 23000 miles. VIN does not have an recalls.
When I make a hard right or left turn sometimes it feels like the inside wheel makes a jolt or slip during the turn. This only happens when I am backing into a spot or turning into a spot, so at low speeds and in parking lots.
I am not sure this is something to do with the electronic steering or what as this is my first car with electronic assisted steering.
I am just hoping its not a suspension or wheel issue.
X-WingYaris is offline   Reply With Quote
Old 09-29-2016, 08:55 PM   #2
Based on what you are describing, I have the same/similar feeling in my '06. Happens in that final few degrees between near full and full turn of the wheel. I'd say it's normal.
Old 09-29-2016, 09:11 PM   #3
X-WingYaris
Drives: Toyota
that makes me feel a bit better. thanks
Old 09-29-2016, 11:19 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Not sure if this is the same as i get, but here goes...
In a car park (while moving slowly), just before reaching full lock, the steering on my Yaris changes from wanting return to straight ahead to pulling to full lock.
This may be unique to Australian Delivery Yarii, as Toyota claim the local delivery version has a "tuned to Australian conditions" suspension setup. For most cars, this means different springs, dampers and possibly camber, caster and toe settings.
It could just be the steering geometry...
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 09-29-2016, 11:32 PM   #5
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
I would describe the behavior of my 2104 the same way.
Toyota yaris 2002 - Hard clutch abhinav_kr DIY / Maintenance / Service 10 06-29-2016 07:08 AM
Songs For Your Current Mood Kaotic Lazagna Off-topic / Other Cars / Everything else Discussions 9 06-08-2009 12:44 AM
hard time putting bumper back on ezhacker1 DIY / Maintenance / Service 4 05-03-2009 08:59 PM
Add another hard drive to a laptop? CompanyXPaladin Off-topic / Other Cars / Everything else Discussions 4 11-23-2008 12:18 PM
