Old 08-21-2009, 10:03 PM   #1
abhinav_kr
Drives: Toyota Yaris
Toyota yaris 2002 - Hard clutch
HI,
I have toyota yaris make 2002. When I purchased this, there was a sound while pressing the clutch and it was very hard. I changed the master cylinder and the sound was gone but I still feel the clutch very hard to press.
Clutch seems fine/easy when I start the car. After driving a mile or half, clutch start feeling hard.
What could be the reason?
abhinav_kr is offline   Reply With Quote
Old 08-21-2009, 10:31 PM   #2
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
what do you mean by hard? like stiff like a race car clutch or just so hard it feels like it's locked up and you'll brake it?
are you the original owner of the car? if not was the car modified or did you have any work done to the car?
RacerFreakXXX is offline   Reply With Quote
Old 08-22-2009, 01:00 AM   #3
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
did you bleed the master and clutch slave cylinders?
Old 08-22-2009, 03:22 PM   #4
abhinav_kr
It's just the stiff clutch. The bitting point is not very low. I don't press the full pedal to change the gear.
It's problem when I have to wait on traffic signals and it's very difficult to keep clutch pedal depressed for a while.
I am not the first owner of the car.
Old 08-22-2009, 07:48 PM   #5
Treyz
~ ambient one ~
Treyz's Avatar
Depends .. was the car modified by its previous owner? It just could be a higher pressure plate or it could be something mechanical. Post up pics too whaile your at it.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 08-22-2009, 09:33 PM   #6
RacerFreakXXX
JDM Fred
lol, that's exactly what I want in my yaris. Sounds like they changed the clutch, imo. It should allow you to shift faster and yes it does suck in heavy traffic.
IMO just work out your legs a bit and get used to it. That or bring it to a mechanic and get charged up the but in expenses and replace everything including the clutch.
Old 08-22-2009, 09:35 PM   #7
TLyttle
TLyttle's Avatar
Drives: 07 Yaris sedan
Doesn't make sense to me: if it is easy when cold, and gets hard after use, something is wrong. Clear to me that heat is the culprit, but how, I don't really know...
Old 08-22-2009, 09:47 PM   #8
RacerFreakXXX
JDM Fred
if it is defiantly hot and cold, fluids expand in the heat, so it must be something to do with your fluids in the line or cylinder.
Old 08-24-2009, 09:49 PM   #9
TLyttle
TLyttle's Avatar
Hm. Maybe there is a stuck relief valve iin the system someplace, likely the master cylinder...
Old 06-29-2016, 06:58 AM   #10
mik23
Drives: yaris 2005
its clutch cable lub it
mik23 is offline   Reply With Quote
Old 06-29-2016, 07:08 AM   #11
Rigaud
Drives: 2009 Yaris
7 years later!!! lmao
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
