Drives: 2005 Belta Join Date: Jun 2013
About 3 years ago I purchased a JDM 11/2005 Belta with a 2SZ-FE engine.
I recently noticed that my Check Engine Light has never lit up even when I have experienced problems, under any condition. When the car is started, all the other status lights turn on except the CEL. Furthermore, I recently had diagnostic check done, and 3 codes where pulled which should have caused the light to appear, P1605, P1589 & P0717. It never did. I took the car to an auto electrician and he was unable to find the cause of the issue but suggested that the CEL bulb was physically removed or disabled in some way by the previous owner. I removed the instrument cluster (its an XP03) and checked it, however the particular cluster uses LED which is soldered to the circuit and it is physically still there. Does anyone have any ideas what this could be? How do I get the CEL working again? Could this be solved by me replacing the instrument cluster? |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Start by checking all your fuses. Assuming your car is the same as my diagram (07 Yaris), the MIL runs off the "7.5A MET" fuse. After that it's time to check the ground wire between the meter and the ECM. Black wire, pin 4 at meter. Pin 24 at ECM.
You'll want to double-check your car's wiring diagram to make sure it's the same but he has likely cut the ground wire. Cheers. |
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
you can use a volt meter to check the continuity through the LED. they do burn out sometimes. then check continuity on wiring harness. then from fuse to battery power source.
| Tags |
| cel, check engine light |
| Check Engine light on after Water Pump change | gumby002 | DIY / Maintenance / Service | 3 | 03-19-2014 10:06 AM |
| help..check engine again | dindy | DIY / Maintenance / Service | 12 | 12-13-2012 07:17 PM |
| check engine light, engine turns but not start | willygoodness | DIY / Maintenance / Service | 10 | 07-23-2012 06:10 PM |
| Check engine light | Geelmeel | DIY / Maintenance / Service | 7 | 11-29-2009 12:32 AM |
| Check engine light flashes during high reving | AlphaFox | DIY / Maintenance / Service | 40 | 08-21-2007 02:43 PM |
