Old 02-08-2014, 05:39 PM   #1
gumby002
Drives: 2008 Yaris Hatchback
Check Engine light on after Water Pump change
Is this normal?
I am sure i have enough coolant i drained 3.5 quarts added 5.
your thoughts and opinions?
gumby002 is offline   Reply With Quote
Old 02-08-2014, 07:41 PM   #2
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Best to scan it ....see no reason why it would happen did u plug in all the plugs for altinator ....also did u let all the air out of the system.
Old 02-08-2014, 08:01 PM   #3
Definitely not normal. My bet is that you damaged the oil control valve while tightening the belt. Look next to the alternator at the cylindrical device that sticks out of the block to see if you damaged it or its connector.
Old 03-19-2014, 09:06 AM   #4
gumby002
Sorry it took a bit to get back.....apparently when i drained the coolant, it left a large "bubble" where the coolant goes. I had to turn the car off and let it cool....the cooling let the bubble get "burped" (my dad's term). Since then there have been no issues with the water pump or coolant.
Check Engine Light on at 32k kilometers? caper26 DIY / Maintenance / Service 21 10-16-2013 12:27 PM
engine check light Capsat DIY / Maintenance / Service 1 06-24-2012 01:03 PM
2000 Vitz check engine light BomB191 DIY / Maintenance / Service 3 05-31-2012 09:35 AM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
