Old 11-04-2016, 07:52 AM   #37
nodi
Drives: Yaris
Have to bump the thread again ...
Maybe someone has already tried swapping the control boards between otherwise identical LHD and RHD clusters (83800-0D660-D and 83800-0D650-D) and can confirm that the pinout / PCB routing is different? I have a slight suspicion that the garbled display might have been due to the flex ribbon cable connecting the VFD being improperly mounted.
Also, does anybody know if an analog cluster with part number 83800-0DG30 is compatible with this Yaris:
VNKKL923.. SCP90L-CHMGKW 11/2005 - 10/2008 SCP90 SOL FRP LHD 2SZFE MTM 5F 5D
Many thanks!
nodi is offline   Reply With Quote
Old 11-09-2016, 05:42 PM   #38
nodi
Drives: Yaris
For the sake of completeness and in case someone faces that same set of problems:
Control boards from digital RHD and LHD clusters are NOT compatible. The PCBs are completely identical, and they will mechanically fit in both LHD and RHD clusters and thus can be swapped between them. However the firmware is different beyond just computing speed and mileage in MPH or km/h - the VFD component for speed and RPM display (basically everything you see enlarged by the mirror) has a different pin out, and the control board firmware takes that into account. I assume the controllers on that board to be OTP, so no chance of reprogramming even if one were to re-engineer the firmware.
Good job the RHD instrument I bought to try this out on was old and came in under £20. Maybe I can now flog it off on ebay for £5 or something.
The analog cluster 83800-0DG30 on the other hand works just fine in said car. Pinout for the vital indicator LEDs seems to be compatible.
Old 08-30-2025, 09:19 PM   #39
2zzYarisRsi
Drives: 2007 Yaris 1.0 3dr
Originally Posted by JudgeM View Post
Thanks for the pics and pointers CTscott.
I had a look and I think I did find the temp sensor. A bit hard to see thru my grills and under the car I have a cover so impossible to see. I've put a picture in the attachments for confirmation. I will check my AC ecu later on for the wires and I will try to add it to the cluster.
More importantly:
I am losing faith in this project of mine. I double and triple checked my extension wiring and still the wrong indicators are lighting up. I even directly connected it to the connector (with great difficulty) and still same problem.
Furthermore, this meter just wont stop beeping. I have a feeling its from a multimatic/auto transmission car and is sad that the transmission is missing. I will confirm this with the seller.
I am seriously considering buying another meter but this time guaranteed from a manual transmission car. I'll try to return the old meter if not, I will just keep it and play around with it for another project.
So can anyone advise on how I can stop the beeping, errors and incorrect indicators ?
An update, with my fumbling around on Techstream, I managed to change the units of the fuel consumption calculator !
Regards,
Did you eventually have any luck with this?
I've just done the reverse of the swap that you did (digital to analog), and have a similar issue.
I also had to cut and extend the wires to just one of the plugs (the opposite site had enough slack to reach), and I'm pretty sure I've joined everything correctly.
The battery icon stays illuminated, and flashes when the indicator / turn signal is on. Other than that, everything else on the cluster seems to be working perfectly.
Any pointers would be appreciated
2zzYarisRsi is offline   Reply With Quote
cluster, digital, gauges, intsrument
Custom Instrument Cluster LED Color Change Service CTScott Items for Sale by private party 74 06-10-2022 01:29 AM
Cruise Control - 07/08 Sedan - Instrument Cluster CB900F2 DIY / Maintenance / Service 4 02-23-2011 07:03 AM
DEAD INSTRUMENT CLUSTER! yaris2010RS General Yaris / Vitz Discussion 21 02-24-2010 12:06 PM
Sedan Instrument Cluster to LB Instrument Cluster Malaya1221 Cosmetic Modifications (Exterior/Interior) 2 12-02-2008 10:05 PM
instrument cluster swap S -> LB elo79 Performance Modifications 1 12-21-2006 10:22 AM
