Old 11-24-2012, 10:34 PM   #1
Yaristeve
Drives: 3-door hatch
sticky ignition switch
Does anyone else's ignition switch hang up in the "Start" position? Twice now, the switch has stuck in the Start position and the starter kept spinning even after I let the key go. I then have to turn key back manually.
Seems to happen only when it's cold. Grease getting gummy when it's cold? Worth taking to dealer?
Old 01-11-2017, 02:13 PM   #2
Bellorank
Drives: Toyota Yaris 2007 Sedan
I have been experiencing the same problem since the time got colder. Took it to the dealer and they said it was the grease in the switch/key barrel, which overtime hardens during cold weather. He recommended adding a small amount of heat carefully (with battery disconnented) to the switch and toggle back and forth with the key in the ignition to loosen up the grease inside.
Bellorank is offline   Reply With Quote
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 09:42 PM
Ignition Kill switch? Deathegg DIY / Maintenance / Service 6 07-05-2011 08:17 AM
Does Ignition Switch ACC provide 12v for remote wire? marco_george In Car Entertainment + Electronics (audio / video / alarm) 7 02-02-2011 12:50 AM
need pinout of ignition switch mikenacarato In Car Entertainment + Electronics (audio / video / alarm) 8 12-25-2008 11:20 AM
Ignition switch heats up kurokoma-kun General Yaris / Vitz Discussion 11 06-19-2007 03:53 PM
