Old 07-02-2011, 11:11 AM   #1
Deathegg
Deathegg's Avatar
Drives: 2010 Yaris hatch
Ignition Kill switch?
Hi Everyone!
I'm looking to install an ignition kill switch on my '10 Yaris hatch (theft prevention). I had one on my Festiva; a simple toggle switch wired into a low power coil wire, worked great. Engine would crank, but not start. (btw, No one ever found my switch that I hid inside the car, including someone I knew years ago who, at one time in his life, stole cars).
How would I go about doing this on a Yaris? Can I do a switch wired into the low power side of the ignition like the Festiva? This car is much more complex than the Festy was. Unfortunately I don't have a shop manual for the wiring diagrams, etc.
And, the simpler the better!
Thanks! :)
"I like the dreams of the future better than the history of the past" - Patrick Henry
Deathegg is offline   Reply With Quote
Old 07-02-2011, 02:03 PM   #2
BLH
Drives: 2007 Yaris Sedan
There is a sticky thread on the 2007 years manuals here.
It may give you an idea on how it maybe wired.
Old 07-02-2011, 05:39 PM   #3
sex
sex's Avatar
Drives: 09 5DR
is this meant to replace the immobilizer or to work in tandem with it?
Old 07-02-2011, 06:02 PM   #4
nemelek
DWEED
nemelek's Avatar
Although I haven't put one on the Yaris, other cars I was able to splice into the ignition wire and hide a switch. Another option would be the wire going to or from the clutch start switch.
Old 07-02-2011, 10:09 PM   #5
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Hit up CTScott on your question...he may even chime in on your thread.
Old 07-03-2011, 09:03 PM   #6
Deathegg
Deathegg's Avatar
No immobilizer on my car, as far as I know. (has manual windows, etc, and the good old regular low-tech key, no remotes, etc)
Wiring it into the clutch switch sounds like a plan; I'll have to look into it.
Old 07-05-2011, 07:17 AM   #7
Is it a manual? We need to push the clutch down to complete the starter motor circuit. So you could achieve a similar effect with a hidden switch on that circuit... You could still bump or push-start the car, though!
Does Ignition Switch ACC provide 12v for remote wire? marco_george In Car Entertainment + Electronics (audio / video / alarm) 7 02-01-2011 11:50 PM
Door trigger for Rear Right RR door missing enve1160 In Car Entertainment + Electronics (audio / video / alarm) 12 12-29-2010 10:14 PM
need pinout of ignition switch mikenacarato In Car Entertainment + Electronics (audio / video / alarm) 8 12-25-2008 10:20 AM
Ignition switch heats up kurokoma-kun General Yaris / Vitz Discussion 11 06-19-2007 02:53 PM
