![]() Drives: Yaris Excel Hybrid Join Date: Oct 2014
Fusebox location
Hi! I need help finding the fusebox. Can anyone give me instructions on how to find it on 64reg Yaris Hybrid Excel please? I need to check if the fuse for my cigarette lighter output is blown. Thank you!
Sent from my iPhone using Tapatalk |
![]() ![]() Drives: 2014 Icon+ 1.33l Multidrive Join Date: Nov 2010
It looks like you have found it and the blown fuse. http://www.toyotaownersclub.com/foru...ighter-outlet/
Just remember, it has blown for a reason. Hopefully it's something relating to the inverter you used.
Haha yes! I was trying all the forums to get some help. Thanks to you and Anthony for detailed instructions on how to find it!
![]() Sent from my iPhone using Tapatalk |
#4 | |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
I haven't tried to use it in the Yaris. Look at the label on the inverter which quotes 20 amps maximum. The fuse is only 15 amps, while the owner's manual says not to use any accessories that draw more than 10 amps to avoid blowing the fuse. If you need to continue using the inverter, consider getting a second socket installed with a suitable fuse rating and uprated wiring.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
| Anyone put in gauges into radio location? | end user | DIY / Maintenance / Service | 2 | 03-18-2016 11:50 PM |
| ECT Sensor location | russ1wat | DIY / Maintenance / Service | 2 | 11-08-2015 02:12 PM |
| Block Heater location | alar | DIY / Maintenance / Service | 4 | 10-23-2012 06:45 AM |
| Fusebox diagram | xedrabmol | DIY / Maintenance / Service | 0 | 09-28-2009 11:50 AM |
| diy factory aux location with aftermarked hu | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 10-28-2008 10:38 PM |
