Old 10-28-2008, 10:38 PM   #1
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
diy factory aux location with aftermarked hu
these are for the people that have a aftermarket hu and want to retain the factory location aux this is so you dont have the mini to mini jack wire running down off the face of the hu or just want to add it if you dont have an i pod
things you would need
rca male to female depending on location 1 to 6 foot
aux input adapter for hu
rca to female mini jack
male mini to male mini jack
drill bit depending on how big the female mini jack
glue gun or glue stick and a torch
ok first step plug aux input into hu
next step find your stock location of the aux or where ever you want to put it. pop out the existing aux jack and chuck it haha.
then take your drill bit. drill out the hole to the exact diameter of the aux
then put the rca to female mini jack input in take your glue gun and surround it let it harden before you let go
then all you have to do know is plug the rcas in run it back to the deck and then enjoy
ill try post pics up as soon as possible to give you a visual look in to how to do it
but the pics will come off a tc but its the same concept
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
DIY: Aux Input Jack Adapter TinyGiant DIY / Maintenance / Service 11 11-10-2012 05:33 AM
Factory armrest install DIY. PetersRedYaris DIY / Maintenance / Service 16 07-27-2012 05:25 AM
Factory AUX Jack ojo In Car Entertainment + Electronics (audio / video / alarm) 1 06-06-2007 09:41 PM
DIY: Painting Factory Brake Calipers redyaris DIY / Maintenance / Service 38 05-26-2007 08:47 AM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
