![]() ![]() Drives: 2012 Toyota Yaris Hatchback Join Date: Feb 2017
Fog Lights?
Has anyone been able to retrofit fog lights from the previous generation (or universals) it looks like the bumper on my 2012 3dr LB has a spot where they would go.
Thanks, Matt |
#2 | |
![]() ![]() ![]() Drives: 2014 Yaris Join Date: Feb 2017
The only difference is the trim piece. You can find trim pieces for the 3rd gen bumper (LE or SE trim specific) with openings for fog lights. The trim piece is just that, a trim piece. The mount for the fog light itself is on the backside of the bumper, and that trim piece is used only as a decorative cover. That said, most (if not all) toyota fog light housings are the same amongst all models. Pick up some toyota specific fog light housings and a basic harness set up along with the proper trim pieces and you're good to go. I found my kit on eBay for like $35, I have a 2014 model with the same bumper set up as yours. Sent from my iPhone using Tapatalk |
All Toyota but the Sienna foglights actually perform well. You'll probably hate the performance and try to upgrade the bulbs. My suggestion would be to pick up a Morimoto XB LED plug-n-play foglight for the Yaris (unless you wanted warmer colors).
https://www.theretrofitsource.com/hi...to-xb-led.html |
#4 | |
Yes, get these! I've been saving for these. Sent from my iPhone using Tapatalk |
Awesome, thank you! Is there a good place to source the fog light trim pieces?
Hmm, I see...
Drives: 2012 Toyota Tundra and Yaris Join Date: Oct 2016
"Everything happens for a reason. Sometimes that reason is you're and idiot"
#8 | |
There ya go. Mine have chrome rings, but these will do for OP. Sent from my iPhone using Tapatalk |
2010EGGHATCH
Drives: White 2010 Yaris Hatch Join Date: Apr 2016
From my experience the fog lights from eBay suck! The trim pieces seem just as good as oem but if still purchase OEM. You can find used OEM on eBay and many insurance sites. I have to agree with kaotic on this one tho, the morimoto is going to put perform even OEM.
Sidenote I used to run aftermarket fogs in my 2010 and they got moisture, cracked, and baked the bowls with regular halogen lights so that's my experience. Sent from my LG-H918 using Tapatalk
IG: 2010EGGHATCH |
#10 | |
I want those Morimoto ones. For now though I have LEDs in my reflector housings. They run cooler than the halogens so they don't melt and look better. I need new LEDs though mine are flickering, but I'll just get the whole Morimoto kit before I get new bulbs. Sent from my iPhone using Tapatalk |
I know these are not the morimotos that everyone has suggested, but these are on micro images ebay page. Would these work okay? Or are they similar to the cheap ones you folks mention?
http://www.ebay.com/itm/172398523528 |
#12 | |
2010EGGHATCH
IG: 2010EGGHATCH |
![]() Drives: 2012 Yaris L 3 Door 5 S Join Date: Mar 2012
m.flores.0928 I used genuine Toyota housing, not very expensive plus OEM OSRAM LED FOGS FOGS from Amazon.uk shipped to US. Osram LEDFOG201 $83.71 and LEDFOG201 TY MOUNT $27.51.
![]() Drives: 2012 5 door & 2008 3 door Join Date: Dec 2013
I have the morimoto led lights in my 2012 and the are the cats meow!
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
I have Hikari LED bulbs in mine, both head and fog.
2 yr warranty and 9600 lumens. It's like natural daylight driving. They have a little fan on back of bulb, so fitment in fog is fine, but headlamp, the covers are snug. If I am to buy again, I would only buy the LED's for the fogs, or go with PIAA yellows for fog and the silverstar ultra or whatever the best halogens are. That said, I am happy with purchase of Hikaris, only disappointment is high beam throw. Work great on my wife's Camry, high beams are the ultras, fogs are yellow PIAA's and low beams are the Hikari LEDS. I consider the Camry bulb selections the perfect set up. I got all lights off Amazon.
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
| DIY yaris III fog lights installation | karloslatynos | Third Gen Yaris General Discussion | 54 | Yesterday 08:40 PM |
| Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal | V70R_Blackbrick | Cosmetic Modifications (Exterior/Interior) | 26 | 11-27-2013 10:14 PM |
| my Projector Fog lights project | ezhacker1 | Cosmetic Modifications (Exterior/Interior) | 3 | 01-10-2010 05:21 PM |
| Fog Lights Poll | Reeves360 | Cosmetic Modifications (Exterior/Interior) | 14 | 12-27-2009 02:00 AM |
| Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) | Lafiro | Cosmetic Modifications (Exterior/Interior) | 2 | 06-12-2009 03:56 PM |
