Old 06-26-2017, 10:52 AM   #1
BAH
Drives: 2007 Yaris
Cruise control problems
I installed the CC as per the instructions from CTScott a couple of years ago on my wife's 2007 Yaris (with indicator light). On Friday, took the car into the shop for regular maintenance and they also did the airbag recall. On the way back home, after picking up the car, my wife found the Cruise Control not working. I took it for a drive. The indicator light will come on when the key is turned to on (car not started), then didn't turn off when the car was started. Pressed the on-off button - nothing. The light will go on and off when you press and hold the lever to 'set' though.
Took the airbag off and checked all the connections under the dash, and under the steering wheel airbag, all looks good.
Just wondering if anyone else has had similar issues.
(Yes, I did a search)
Thanks in advance.
BAH is offline   Reply With Quote
Old 07-04-2017, 07:41 AM   #2
BAH
Drives: 2007 Yaris
87 looks but nobody has an idea.
Well, no worries, i found the problem and will share it.
It seems, that when I had the dealer change the fresh air filter, they must have snagged the wire going through the dash and it came apart at the butt connection I had there. Re-attached and cruise control works again.
Old 07-04-2017, 01:28 PM   #3
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Glad you got it figured out.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Rostra 250-1731 cruise control kit for Yaris PeetYaris In Car Entertainment + Electronics (audio / video / alarm) 5 06-26-2011 06:48 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
