![]() Drives: 2008 Yaris Sedan Join Date: Feb 2017
Rattling Noise When Turning?
Hey, so basically my car makes i think a rattling noise when the steering wheel is spun all the way to either side, most noticeable when doing u-turns. It's definitely coming from the front and only when the wheel is turned in one direction almost all the way.
Any ideas what is is? Could it be a worn out joint in the front suspension? 08 Yaris Sedan (170K KM), bought it at 160'ish.. Edit: It might be just only when i go fully left on the steering wheel, haven't really examined it thoroughly yet. Last edited by Jboss; 08-21-2017 at 12:14 AM. |
![]() Drives: Asolute Red 15 Yaris Join Date: Aug 2017
Tin can type rattle? CV boot ripped and joint bad.
That would be the first thing to check.
Sir Rustalot
Drives: Toyota Yaris silver 2000 reg Join Date: Sep 2017
Cv would be better then the alternative .....rack and pinion! Hope its a cheap and easy repare for you,mines in the garage for quite a bit of repare and TLC ....,anti roll bar bushes ,wheel bearings,rear brake load sensing valve ,welding on sill,rear seat belts (dog ate them) all in £180
If it wasnt for my modesty ,i would be perfect !
Sir Rustalot
Replacement sill so thats another£130 on the bill
So i actually haven't gotten around to having it checked.. Going for an oil change today at my mechanic and he'll have a look at it. Is the joint bad if the tin can rattle sound only comes up when the wheel is turned 100% to either direction or could it just be the cv boot?
I got quoted $250 per side for each "cv joints" but that's without having a look at the car. The car i bought for $4000 and already put some money into it on repairs lol.. Like new battery, serpentine belt.. |
The parts are available on Amazon for like $150 for both axles. Check it out.
I would be shopping around for a price. How many miles on the car?
Okay so it turns out my mechanic bent something and the noise is gone. I googled up tin can rattle and it was no where near that noise, it was just like a minor grinding noise of some sort. I don't know what he bent though lol, maybe a shield or guard somewhere?
Mystery solved at no expense. GREAT!
This mechanic i actually found off a local forum, he's a pretty honest guy and is really busy. Maybe i should have listened more clearly but still a mystery lol. Either something at the back of the wheel/tire or back side of the car even though the sound was coming from the front of the car.
| RATTLING NOISE EXHAUST PIPE/BACK OF ENGINE | joeljcruz86 | DIY / Maintenance / Service | 15 | 09-13-2014 06:46 PM |
| Various problems with service at shop (green coolant and accelerator rattling noise) | LilyOfTheYaris | DIY / Maintenance / Service | 4 | 04-08-2014 10:31 PM |
| AC makes a rattling noise when turned on. | gabriel2012 | DIY / Maintenance / Service | 8 | 07-12-2011 06:03 PM |
| Rattling noise when stopped | herkfsu | DIY / Maintenance / Service | 2 | 02-28-2011 01:32 PM |
| annoyin noise (ticking or rattling) on idle.. | abdallah380 | DIY / Maintenance / Service | 2 | 04-18-2009 05:40 PM |
