#1 |
![]() ![]() Drives: 2011 Base Sedan Join Date: Oct 2010
AC makes a rattling noise when turned on.
Kinda wierd, I was driving around and my friend called me so I turned down the radio...once I finished talking I heard a rattling noise(quiet since the ac was set to 2)
I didn't think it was the ac, just something inside making noise against one of the plastic panels or something....until I turned the thing into 4....started rattling like crazy. then I stopped and popped the hood and noticed the noise was louder. I can describe the noise as *clack clack clack clack clack* checked the fan to see if something got stuck in there but no luck.
http://db.tt/QIWZ2E2 Click to signup for dropbox, and get bonous space, I do too! |
If you don't have a cabin air filter installed then it is probably something stuck in the fan. Pull the lower passenger glove box to take a look. If you flip the AC intake knob to full recirculate you will be able to look right into the fan.
#3 |
I have a cabin air filter(replaced it a few months ago) its installed. do I try it anyways?
#4 |
air filter had some dust but when I took it out there wasn't anything inside the white circular thing that spins when the ac is on.
#5 |
Did you run it with that open to see if the rattle is coming from in there?
#6 |
yes I ran it, but the clicking noise can be heard louder when I pop the hood...I really hope its not the compressor my car only has 46k miles.... my highlander has 200k and I haven't had any problems with the AC :/
When I tested this out, the clicking was soft when the ac was off....getting louder and louder as I moved up to 4.
#7 |
Got it checked out at 2 a/c shops today...both found the culprit to be the compressor going bad and the noise is coming from something lose inside of it.
the first shop quoted an aftermarket compressor(new) at $1,039 installed. the second shop quoted Aprox. $550...the compressors is around $300(rebuilt) + trading in the bad one. the labor would be around $175 + tax which would bring it up by $550 total. The dealer quoted $2,100 for the whole job.... I need to fix it...the heat wave in Puerto Rico isn't getting any cooler.
#8 |
Local Sh*t Disturber
Drives: 2009 Yaris LB Join Date: Aug 2009
Ya the compressor took a shit, its the clutch bearing that probably went out....
You think your Yaris is low and fitted LOLzzzzz |
#9 |
:/ there goes my pay check... going to check out the warranty from the rebuilt one...
This sucks, I was going camping with the yaris so we could save gas on the 2hour trip...gotta get there on the old highlander now :/
| Rattling noise | FunkyCole | DIY / Maintenance / Service | 10 | 08-27-2015 07:28 PM |
| Yaris makes a grinding noise while turning | jonathankoji | DIY / Maintenance / Service | 7 | 07-06-2011 08:01 AM |
| Rattling noise when stopped | herkfsu | DIY / Maintenance / Service | 2 | 02-28-2011 02:32 PM |
| annoyin noise (ticking or rattling) on idle.. | abdallah380 | DIY / Maintenance / Service | 2 | 04-18-2009 06:40 PM |
| Rattling Noise with A/C Fan? | Sabretooth | DIY / Maintenance / Service | 16 | 05-15-2007 04:27 AM |
