New Tachometer
i just got another tachometer. this one is too nice to build a pod on, so i'm going to build a gauge cluster and install it properly.
Doesn't go high enough... #aboutthatrotarylife
I wouldn't mind having a tach again.
Ha. |
![]() ![]() Drives: 2012 Black sand pearl <3 Join Date: Feb 2018
Where are you planning to put the gauge cluster? I’ve been thinking about putting one above my steering wheel in the removable compartment on mine. It would be nice to have a bezel for it though
right now i built a pod on the back of a little cheap-o and mounted it in the glove box.
i think i'm going to get a thick piece of plexiglass and bend it into an "L" shape and frame in some side pieces. then i'm going to cut a square out of the glove box to mount. behind the door, i am going to mount a power strip and a ground strip to make powering gauges and other things up there easier. |
I made a backing plate for mine and removed teh glovebox in full. i need to spend more time on it as i want to redesign how it looks and works,
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
I think a much cleaner solution is to get a OE Canadian instrument cluster which includes a tachometer. The only drawback is the speedometer is in km/hr with miles/hr shown below in a smaller font.
yeah, but the Canadian one still does not have a water or oil gauge. the main concern is water temp. i did not want to goop filler on the nice water gauge ether, so the best option is to build a cluster onto the glove box. plus, it's way more fun to build stuff than to plug stuff in...
| Tags |
| gauge, racetech, tach, tachometer |
| Tachometer install | 07YarisUS | Cosmetic Modifications (Exterior/Interior) | 3 | 02-22-2016 01:44 PM |
| Tachometer | 09BoostedVitz | Performance Modifications | 12 | 07-21-2011 10:48 PM |
| Manual with no tachometer tips | maineyaris | General Yaris / Vitz Discussion | 10 | 02-01-2011 05:42 PM |
| No speedometer or tachometer lights during day | cdavidhess | DIY / Maintenance / Service | 20 | 06-30-2009 11:38 AM |
| Source code for Yaris Tachometer | metalshark | DIY / Maintenance / Service | 27 | 04-06-2009 01:41 AM |
