Old 09-21-2018, 09:21 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Latest fuel economy
Imperial gallons, but still pretty good...even though I have been stepping on it a little harder lately.
Old 09-22-2018, 01:33 AM   #2
scylla
Drives: 2015 Yaris L
51 US gal.!? Are you hypermiling?
scylla is offline   Reply With Quote
Old 09-22-2018, 07:27 AM   #3
06YarisRS
I think that's only about 37 mpg US. Not hypermiling. If anything, probably a bit higher drag coefficient with my rear spoiler, lip and somewhat 'textured' paint job.
Old 09-24-2018, 04:16 PM   #4
matti
Drives: 2017 Yaris L (5sp manual)
Thanks for sharing.
My last five tanks or so have been between 43-45 mpg. Cool weather is setting in, so mpgs will be dropping soon, unfortunately.
matti is offline   Reply With Quote
Old 09-24-2018, 06:01 PM   #5
06YarisRS
43 - 45 mpg (US)? That's amazing! They are such great, fuel efficient cars. I bet the manual trans makes a difference.
Old 09-24-2018, 08:05 PM   #6
matti
Ha, yes I'm sure the MT helps. I'm a pretty relaxed driver and take it relatively easy, but I'm certainly not a hypermiler or anything like that!
Old 10-13-2018, 09:14 PM   #7
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
Wow, must be a ton of flat roads and minimum stops in your area. I struggle to break 34mpg and would only get over 40mpg on 400 mile trips where I draft behind large trucks going at about 50-55mph. If I go 60-65mph, my mpg drops right back to around 35mpg.
07liftback is offline   Reply With Quote
Old 10-18-2018, 09:22 AM   #8
matti
I have to go up one hill on the way to work; it's maybe 1.5 miles long and 6-8% grade, I suppose. However, I get to come down it every day, too! Other than that, there are about 5-6 stop signs/traffic lights on my daily commute, but almost no stop-and-go.
Old 10-18-2018, 10:48 AM   #9
i got the sticker-rated 5.5L/100km on our first tank in our 2007 yaris back in the day. went from fredericton to moncton, to the confederation bridge, to the border of NB and NS, back to moncton and then fredericton....all on one tank using back roads (80kph).
i never did that well again on a tank of gas in the 5 years we had the car, lol. always mid-6's.
Old 11-10-2018, 08:55 PM   #10
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
28.5 mpg
DarkShadowFox is offline   Reply With Quote
Old 11-21-2018, 02:12 PM   #11
matti
Well, the cold weather has hit. Down to 36 mpg, and likely to drop further.
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
New CAFE rules nearly double fuel economy by 2025 digitalrain Fuel Economy Forum 27 02-24-2012 11:49 PM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
