Latest fuel economy
Imperial gallons, but still pretty good...even though I have been stepping on it a little harder lately.
![]() ![]() Drives: 2015 Yaris L Join Date: Jun 2017
51 US gal.!? Are you hypermiling?
I think that's only about 37 mpg US. Not hypermiling. If anything, probably a bit higher drag coefficient with my rear spoiler, lip and somewhat 'textured' paint job.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 09-22-2018 at 09:30 AM. |
![]() ![]() ![]() Drives: 2017 Yaris L (5sp manual) Join Date: Jun 2012
Thanks for sharing.
My last five tanks or so have been between 43-45 mpg. Cool weather is setting in, so mpgs will be dropping soon, unfortunately. |
43 - 45 mpg (US)? That's amazing! They are such great, fuel efficient cars. I bet the manual trans makes a difference.
Ha, yes I'm sure the MT helps. I'm a pretty relaxed driver and take it relatively easy, but I'm certainly not a hypermiler or anything like that!
![]() ![]() Drives: 07 Yaris Liftback Join Date: Nov 2010
Wow, must be a ton of flat roads and minimum stops in your area. I struggle to break 34mpg and would only get over 40mpg on 400 mile trips where I draft behind large trucks going at about 50-55mph. If I go 60-65mph, my mpg drops right back to around 35mpg.
I have to go up one hill on the way to work; it's maybe 1.5 miles long and 6-8% grade, I suppose. However, I get to come down it every day, too! Other than that, there are about 5-6 stop signs/traffic lights on my daily commute, but almost no stop-and-go.
i got the sticker-rated 5.5L/100km on our first tank in our 2007 yaris back in the day. went from fredericton to moncton, to the confederation bridge, to the border of NB and NS, back to moncton and then fredericton....all on one tank using back roads (80kph).
i never did that well again on a tank of gas in the 5 years we had the car, lol. always mid-6's.
Drives: 2015 Yaris LE 3door 1F7 Join Date: Feb 2017
28.5 mpg
Well, the cold weather has hit. Down to 36 mpg, and likely to drop further.
| Odd Fuel pump issue. Feeling at a loss. | Marchalis | DIY / Maintenance / Service | 4 | 03-06-2018 09:55 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 04:34 AM |
| New CAFE rules nearly double fuel economy by 2025 | digitalrain | Fuel Economy Forum | 27 | 02-25-2012 12:49 AM |
| 2012 Camry | Kal-El | Off-topic / Other Cars / Everything else Discussions | 26 | 10-02-2011 10:20 PM |
| NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 07:38 PM |
