Old 03-03-2019, 03:19 PM   #1
2bz
Drives: 2008 Yaris 3DR Hatch MT
Grinding MT 1st gear only
Shifting down to 1st gear has just started to grind. No other gears grind up or down. Did a gear oil change with Mobil 1 75W90 about 6 months ago.
Syncro on 1st going? Clutch dragging? Shift linkage? Something else?
Thanks.
2bz is offline   Reply With Quote
Old 03-03-2019, 04:53 PM   #2
2bz
Looks like the consensus is synthetic GL-5 lube is shit for Toyota MTs. Going to try swapping it out with some GL-4 Dino.
Old 03-04-2019, 02:26 AM   #3
komichal
Just make sure you go for the original Toyota 75W.
I tried Valvoline 75W90 GL4 (replacing the original oil after nearly 200tkm). It was OK but the gearbox started to grind occasionally and the shifting from 1 to 2 in cold weather (-10 Celsius) was hard.
So after a year I changed it to Elf 75W80 (yes, 80 - recommended by Elf) GL4. Cold shifting problem is gone but slight grinding occurs now and then. I would say it is acceptable but next time I would definitely go for Toyota original oil. I have no problem with using non-Toyota liquids for engine oil or coolant or brakes (as long as they match the required specs) but this gearbox seems to be a real gourmet.
Do not make the same mistake as I did and go for original oil directly. It costs a bit more but it is worth it!
Old 03-04-2019, 08:24 AM   #4
dogsridewith
Drives: 2007 2-door hatchback
Mobil 1 synthetic transmission gear oil Yaris first gear grind synchro double clutch
Does this Yaris even have a first gear synchro? Very tight w/ whatever fluid was there when I got the car. Same way w/ Mobil 1 75/90. Wondered why the new Mobil 1 had a faint odor of that rank gear oil smell. Seems like a candidate for counterfeiting.
Old 03-04-2019, 11:04 AM   #5
tmontague
tmontague's Avatar
Before I had my clutch type LSD I had good luck with Amsoil MTG, it was smoother than redline MT-90 that untried before it handled the cold really well. It is a proper GL-4 iirc.
The MTG wasn't a good fluid for my LSD so I now use Redline MT-85 and no grinding issues really, and it is a great fluid for a clutch type LSD.
As others stated, stick with a proper GL4 and you should be fine
Old 03-04-2019, 11:15 AM   #6
dogsridewith
Toyota Yaris manual transmission oil specification
2007 Owner's Manual for USA/Canada specifies API GL-4 or GL-5 w/ viscosity of SAE 75W-90
Old 03-04-2019, 11:37 AM   #7
2bz
I bought CRC Sta-Lube GL-4 85W90 conventional (dino). Should be able to replace the Mobil 1 within the next few days.
Old 03-07-2019, 07:53 AM   #8
Mask Rider Blac
Drives: 2013 Yaris Sedan MT
Sent from my SM-G7102 using Tapatalk
Mask Rider Blac is offline   Reply With Quote
Old 03-07-2019, 10:43 AM   #9
suprf1y
suprf1y's Avatar
Drives: 05 Echo
I'm surprised nobody here uses Synchromesh MTF. It's a GL4 and especially good for cold temperature and fuel economy applications, and it's fixed a bad 1-2 grind for me a number of times
https://www.pennzoil.com/en_ca/produ...2NhbGU9ZW5fY2E
suprf1y is offline   Reply With Quote
Old 03-07-2019, 12:42 PM   #10
IllusionX
Drives: 07 Yaris Sedan Aero
I believe I've used RoyalPurple Synchromax in my transmission after trying Castrol syntec 75W90 and was pretty bad for the transmission.
RoyalPurple was not better, and obviously the wrong type of oil. Drove it a while, then change it to Amsoil GL4.
Transmission has been better since, but I still get the occasional grind shifting into 1st while not 100% stopped. But I'm still grinding shifting from 3rd to 5th when reving high.
Old 03-08-2019, 10:15 AM   #11
suprf1y
suprf1y's Avatar
Drives: 05 Echo
How was it bad for the transmission?
Old 03-08-2019, 10:28 AM   #12
IllusionX
RP Synchromax? It's not the right oil for this transmission. It would grind shifting into 1st, and 3 4 and 5th high reving. Just go with proper oil and you shouldn't have problems.
Old 03-08-2019, 01:19 PM   #13
2bz
Changed to Dino GL-4. No more grinding. Life is good.
Old 03-08-2019, 02:37 PM   #14
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
Or use this.
https://www.amazon.com/gp/product/B0...T3K61MGZAFAK4E
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Old 03-08-2019, 03:57 PM   #15
dogsridewith
Dino GL-4 for synchromesh
Will try to replicate. Why did you opt for the Dino brand of GL-4?
re: 2-1 grind w/ the Mobil 1--was this shift also quite stiff? (Mine takes too much push to happen, but there isn't an audible grind or bite felt in the shift lever.)
Old 03-08-2019, 05:59 PM   #16
2bz
Dino as in dinosaur (conventional, not synthetic). It was CRC Sta-Lube gear oil. Yes, on the stiff. But I had grinding on 2>1 and occasionally 2>3. Nice and smooth all around now.
Old 03-08-2019, 09:48 PM   #17
dogsridewith
and, per your #7 post, 85w90 weight...which sould be a little thicker at low temperatures than the other oils mentioned in this thread.
2nd gear grinding BoostedTRD DIY / Maintenance / Service 6 10-31-2019 09:53 PM
1st gear shaking and very stiff clutch Olea DIY / Maintenance / Service 9 03-23-2019 11:07 AM
problem of gearing, 1st and 2nd gear, Yaris 2008, 1.3 VVTi 64 kw cylaptor DIY / Maintenance / Service 18 03-05-2019 11:40 AM
Grinding noise in 1st and reverse spookybathtub DIY / Maintenance / Service 0 01-24-2015 09:21 PM
Strugeling 1st gear!!?? mhkritzinger DIY / Maintenance / Service 15 02-06-2010 11:25 AM
