Old 04-12-2017, 09:08 AM   #1
BoostedTRD
Drives: 09 Yaris Hatchback
2nd gear grinding
So my 2nd gear has started grinding whenever I downshift from 3rd to 2nd over 30mph. If I wait until the car gets to 20mph I can downshift from 3rd to 2nd without any grinding. I changed my tranny fluid about 10k ago and I started using Red Line MT90, soon after changing it to Red line is when I started noticing but it has gotten worse. Since I don't want to force it into second gear I have gotten used to downshift only when it reaches 20mph.
Will I have to replace the 2nd gear synchros? or can a better quality transmission oil help it out?
On my turbo honda civic third gear was grinding at some point and I started using GM Synchromesh oil and that stopped the grinding. So I am wondering if I can do the same for the yaris... Any suggestions will be greatly appreciated.
BoostedTRD is offline   Reply With Quote
Old 04-12-2017, 02:36 PM   #2
I had an issue with downshifting to 4th. It wasn't until I changed to Royal Purple 75-90 GL4 that it fixed the problem. That was over 2 years ago now.
Old 04-13-2017, 07:21 AM   #3
BoostedTRD
Thanks for the suggestion, I will try Royal Purple and see what happens.
Old 10-23-2019, 12:30 PM   #4
jeffreyd
Drives: 2008 Yaris Liftback, 5-speed
Did The Royal Purple Help?
I have the same issue. The car has 138,000 miles though.
I can avoid grinding, but my wife cannot and I want to avoid gearbox issues. If changing the gearbox oil helps, I'm in!
jeffreyd is offline   Reply With Quote
Old 10-23-2019, 03:44 PM   #5
komichal
I tried a few oils, all of them met Toyota requirements.
But the original Toyota is by far the best.
I was very pesimistic about it (I always am when the discussion about any oil pops up) but this original Toyota stuff is really the best.
Old 10-31-2019, 09:26 AM   #6
zoidberg444
zoidberg444's Avatar
I've heard these gearboxes prefer GL4 dino oil rather than some of these fancy all singing all dancing synthetic oils. I think the Toyota recommended oil for these gearboxes is a single weight not a multi weight. I use this cheap 75W90 semi synthetic GL4 stuff made by Comma and my gearbox seems to be behaving itself.
UK to Nordkapp in a Yaris
Old 10-31-2019, 08:53 PM   #7
xxcanuckxx
Drives: 2015 SE HB
Royal purple here too. I put 380,000 km on my 2007, original clutch and transmission. Worst to happen was that downshift to first would grind if I didn't slow down to less than 10km/h.
Sent from my SM-G950W using Tapatalk
xxcanuckxx is offline   Reply With Quote
2nd, 4th & Reverse Gear Not Engaging mesci DIY / Maintenance / Service 3 03-17-2023 07:03 AM
Stuck in 2nd gear! Surubi Suggestions - Feedback - Questions 3 03-01-2015 03:17 PM
2nd Gen owner's impressions: 3 days with a 3rd Gen (2013 5-door LE 18k miles) nookandcrannycar General Yaris / Vitz Discussion 7 02-22-2014 08:16 PM
2nd Gear lock out heeroyuy01195 DIY / Maintenance / Service 4 12-29-2011 01:44 PM
2nd to 3rd gear shift (manual tranny) tekmoe General Yaris / Vitz Discussion 13 12-11-2006 06:27 PM
