Old 12-28-2011, 07:42 AM   #1
heeroyuy01195
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles
2nd Gear lock out
Anyone having issues shifting into 2nd gear? Since I bought the car back in 06' it had a tendency to lock me out of second gear. To be a little more specific, when up-shifting or down-shifting into second, it will go halfway then just stop. Its as if the shifter is being pressed against something and just won't go all the way into second. Sorry if that description was confusing but I can't think of a better way to describe the situation. Has anyone had any problems like this?
heeroyuy01195 is offline   Reply With Quote
Old 12-28-2011, 08:53 AM   #2
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
My car does this when cold. I wont even be able to put it into second until i pump the clutch a couple times or wait for the engine to warm up some. I blame alot of it on the shitty royal purple thats in the trans now. Once i go down the road alittle ways and the fluid in the trans gets movin around its perfectly fine after that. It never grinds into gear.
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 12-28-2011, 09:25 AM   #3
heeroyuy01195
That's the odd part, it does it regardless of temperature. I guess I'll try changing out the tranny fluid and see what happens. Either that or I need to pump my clutch at every stop light lol.
Old 12-29-2011, 11:48 AM   #4
bronsin
bronsin's Avatar
I would guess the shifter cable is not assembled to the transmission right.
Old 12-29-2011, 01:44 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
If it's not the fluid or the cable links, then it's likely something in the transmission itself: synchro, hub, arm, etc. Not cheap to pull it off and tear it apart.
Judder/ lack of power @low Rpms in 2nd gear? 1998 1.3 razorricky DIY / Maintenance / Service 2 01-02-2009 05:44 PM
November 2nd, Sunday - Mosport DDT lapping event, Last event of the season!! Touge.ca Canada 0 10-31-2008 12:45 AM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
2nd to 3rd gear shift (manual tranny) tekmoe General Yaris / Vitz Discussion 13 12-11-2006 06:27 PM
