Old 03-20-2019, 04:43 PM   #1
Bikerboy89
Drives: 2015 Yaris Liftback LE auto
Getting power inverter cables through the firewall.
Hello I'm trying to figure out if there's a known open hole or grommet in the firewall to get through into the cabin on an automatic 2015 Yaris? It needs to be a decently sized hole because I need to run positive and negative 6 gauge cables through it.
Bikerboy89 is offline   Reply With Quote
Old 03-20-2019, 10:52 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
I ran a 0awg through the gromet on the driver side of the firewall. Not sure if it still exist in the 2015. But I don't see why not if the ECU is still on the firewall.
Old 03-20-2019, 11:00 PM   #3
Bikerboy89
Okay thanks I'll have to look a little harder.
Power inverter & flat deck (looking for insight) David C DIY / Maintenance / Service 4 12-13-2016 08:24 PM
2013 Power Window already has a fuse? SecondYaris Third Gen Yaris General Discussion 0 03-06-2016 07:12 PM
Power lock questions Taiyaki DIY / Maintenance / Service 22 04-22-2009 10:22 PM
