![]() Drives: 2015 Yaris Liftback LE auto Join Date: Mar 2019
Getting power inverter cables through the firewall.
Hello I'm trying to figure out if there's a known open hole or grommet in the firewall to get through into the cabin on an automatic 2015 Yaris? It needs to be a decently sized hole because I need to run positive and negative 6 gauge cables through it.
I ran a 0awg through the gromet on the driver side of the firewall. Not sure if it still exist in the 2015. But I don't see why not if the ECU is still on the firewall.
Sent from my CLT-L04 using Tapatalk |
| Power inverter & flat deck (looking for insight) | David C | DIY / Maintenance / Service | 4 | 12-13-2016 08:24 PM |
| 2013 Power Window already has a fuse? | SecondYaris | Third Gen Yaris General Discussion | 0 | 03-06-2016 07:12 PM |
| Power lock questions | Taiyaki | DIY / Maintenance / Service | 22 | 04-22-2009 10:22 PM |
