![]() ![]() Drives: 2008 Yaris Join Date: Sep 2014
MAF check engine light
Long story short - had a cold air intake on my 08 yaris for 4 years. Had to restart the battery when I first installed it and it had no issue relearning. Had an oil change 3 weeks ago and had the mechanic put on a new filter while it was lifted. He didnt put it on all the way and it fell off, but I caught it after a few miles. Put it on correctly, cleaned the MAF, and reset the computer. Now the MAF is throwing a check engine light randomly but will turn off after the car being off for a while. It's done this 3 times. It always trips while on the highway going up hill. Should I get a new sensor? Any idea what could be causing this?
Make sure the MAF is seated correctly and you haven't damaged the o-ring.
By o-ring do you mean essentially a gasket between the sensor and intake?
I should note that the idle and gas mileage haven't changed and I can't hear any interruptions in the engine noise, even when the light trips. |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
What is the code? There's more then one MAF related check engine code. MAF sensor's (especially OE quality ones) can get quite pricey so I wouldn't go buying a new one unless you're certain it's the problem.
Did you clean the MAF with proper MAF cleaner spray?
I did clean it with proper MAF cleaner. The exact code is P0101. How would I know if it wasn't seated properly? It seemed to reinstall after the cleaning like normal.
I reset the computer, really cleaned the MAF again and let sit for a longer time to dry, and let it idle for a good 10 minutes after the reset. So far no check engine light, will keep posted.
I got a rebuild maf From Napa about eight years ago for $80 for my sons 2000 and echo. Same part on the Yaris. It still works so if you need a new one no biggie.
| help..check engine again | dindy | DIY / Maintenance / Service | 12 | 12-13-2012 06:17 PM |
| Cold air intake....check engine light on...??? | JohnnyMalice | Performance Modifications | 4 | 04-29-2012 09:46 PM |
| Differntial diagnosis for the check engine light yaris sedan | dante2086 | DIY / Maintenance / Service | 1 | 12-18-2010 09:04 AM |
| Check engine light | Mr Yarisman | Performance Modifications | 7 | 10-24-2009 11:10 PM |
