Taco Supreme
Drives: 06 Yaris RS Hatch Join Date: Jul 2020
Hella sharptones
Hey guys first post here, I've had an 06 Yaris rs since November, and the horn stopped working recently, I always thought it was pathetic compared to my Tacoma which isn't great either, anyways I had ordered a set of shaprtones for the Tacoma, but since the Yaris horn is no good(checked relay, and fuse hooked horn directly to power and nothing) I wanna use the sharps since I've been run into the shoulder about 10 times in the last two weeks alone. Has anyone run these? I've seen some old supertone writeups, but just wanted to see some setups
#2 | |
2ZR swap. DO IT! Ask how!
Make sure you've got a solid ground connection. The horn uses the radiator supports as the path back to the battery and any corrosion between the sheet metal parts will mess with that. If you have a multimeter, check for voltage between the ground terminal on the battery and the positive side of the horn.
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
I had a pair of Sharptones on my old '99 Tercel, bloody hell they were loud. Not sure I want to put them on the Yaris yet.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
| Hella micro de install | nortonfb | DIY / Maintenance / Service | 3 | 03-24-2014 09:36 AM |
| Seeking Hella Tailight | Slacky | Willing to Buy by private party | 0 | 09-16-2013 11:10 PM |
| Another Hella Supertones Install | jpmck03 | Performance Modifications | 2 | 05-27-2013 06:45 PM |
| Hella taillights installed | Brian | Cosmetic Modifications (Exterior/Interior) | 20 | 09-18-2011 11:41 AM |
| Hella LED Combination Rear Lamp for Yaris Sedan!!! | blackgenius007 | Cosmetic Modifications (Exterior/Interior) | 17 | 01-04-2010 11:51 PM |
