Old 04-09-2010, 12:00 AM   #1
Brian
Brian's Avatar
Hella taillights installed
I just finished installing the new Vios Hella taillights I got from Garm. I must warn you that if you don't already have an aftermarket set of taillights, series 5 or altezza, there will be more wiring involved and you will need the plugs for the bulbs that mount into the taillight. I need to get plugs for my reverse bulbs. The lights do not come with bulbs. I will post pics this weekend of the back of the light. If you don't already have aftermarket taillights it is still possible to make them work. Here is the wiring info. It's the same as the series 5. Atleast the way I did it, it is.
Wiring
Driver's side OEM
Purple=brake
Brown=reverse
Green=illumination
White w/black stripe=ground
Light green=turn signal
Passenger's side OEM
Orange=brake
Red=reverse
Gray=illumination
Yellow=turn signal
Hella (same for both lights)
Green w/yellow stripe=turn signal
Red w/blue stripe=reverse
Green w/white stripe=brake
Solid green=illumination
and the pics
Lights on
Brake lights
Reverse light
Old 04-09-2010, 12:23 AM   #2
Stove
Stove's Avatar
Drives: 2010 Yaris 5 Door
Very not bad
Stove is offline   Reply With Quote
Old 04-09-2010, 01:03 AM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I like them more than I thought I would. Definitely better than stock IMO.
Old 04-09-2010, 01:21 AM   #4
TKO
Drives: 4 door hatch
Very cool...how is the light output from these badboys?
TKO is offline   Reply With Quote
Old 04-09-2010, 01:24 AM   #5
Brian
Brian's Avatar
They're brighter compared to my series 5 taillights. The red lens helps increase the brightness of the red l.e.d.'s.
Old 04-09-2010, 12:03 PM   #6
severous01
hmmm...y did they only make them in sedan...i'm so jealous
Old 04-09-2010, 12:42 PM   #7
keep us posted on what plugs/bulbs you need, so I can make sure other customers know what they have to do. Thanks for posting up so quickly!
Old 04-09-2010, 12:47 PM   #8
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
beautiful.
Old 04-21-2011, 01:21 PM   #9
abo raya
Drives: yaris
from where did you buy it
abo raya is offline   Reply With Quote
Old 04-21-2011, 01:25 PM   #10
Brian
Brian's Avatar
http://shop.microimageonline.com/Hel...s-rshel-01.htm
Old 04-22-2011, 12:09 AM   #11
abo raya
Drives: yaris
thanx man
whats written on it
made in......?
Old 04-22-2011, 01:05 AM   #12
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
best taillights for a sedan
Old 04-22-2011, 03:36 AM   #13
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
me too....I like them better than my TYC tails
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 04-23-2011, 01:01 AM   #14
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Those tails are sweet....car looks sweet with them.
Old 04-23-2011, 01:42 AM   #15
hedowich
Drives: Yaris 11
nice
hedowich is offline   Reply With Quote
Old 08-09-2011, 02:28 PM   #16
hengemann
Drives: 2000 Yaris Sedan
do you know if this light are compatible with a toyota echo sedan 2k??
hengemann is offline   Reply With Quote
Old 09-17-2011, 09:05 AM   #17
ciscobear
Drives: Toyota Belta
Hey Brian or Garm, could see the back of the light? Comparison with a stock lamp, the plugs we need to get and/or part numbers?
ciscobear is offline   Reply With Quote
Old 09-17-2011, 11:40 AM   #18
^ I can take a pic later today. No plugs or part numbers needed, just wire them up.
Wire color scheme is on the product page.
If you want plug 'n play, you can take the connectors from your old tails or buy just those two parts from Toyota.
Series 5 taillights installed Brian Cosmetic Modifications (Exterior/Interior) 30 05-12-2009 06:05 AM
JDM Blk Taillights Replicas ... TitaniumBarbell Cosmetic Modifications (Exterior/Interior) 15 05-08-2009 10:44 AM
New leds taillights installed!!! Yaris_PR Cosmetic Modifications (Exterior/Interior) 5 04-06-2009 06:35 AM
Tanabe NF210's installed...got a question though Terrorize Wheels, Tires and Suspension Forum sponsored by The Tire Rack 32 09-29-2006 07:45 AM
