Old 12-01-2020, 10:28 PM   #1
SirDigby
Drives: 2007 yaris 3 door
NST Pulley FAILURE!!
hello. check out my sweet pulley!
all other pulleys turn freely.
water pump turns freely.
i can't find any explanation except the pulley itself being made from poop.
you know, for $86 you'd think a company was using quality materials...
Old 12-01-2020, 10:37 PM   #2
JustDidIt
JustDidIt's Avatar
Drives: '08G2T Prius
Define spins "freely". Looks like to me you had the WP fail, locking up or at minimum not spinning as well as it should causing the belt to rub through the aluminum. how did you not hear or feel this happening. Definitely not a NST pulley issue imo looks like negligence.
JustDidIt is offline   Reply With Quote
Old 12-02-2020, 12:58 AM   #3
SirDigby
water pump is fine. turns without effort. bearing is nice and tight. pump was replaced 25,000 miles ago. coolant is fine. 25,000 miles. pink. it did not make any noise ever until yesterday. today it was louder, so i was checking for an issue. there is not any drag what so ever. all other pulleys are in perfect shape...
Old 12-02-2020, 10:42 PM   #4
Jason@SportsCar
We only use OE pulleys now. Some years ago we had the NST crank pulley leave the crank.
Old 12-03-2020, 04:06 PM   #5
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Pretty sure I had that happen twice with the Blitz installed on my 1NZ. Not a great way to spend your commute.
The reason you're paying so much for it has more to do with the limited runs. You can't get the same economy of scale that the OEMs do when they negotiate a contract for a million units per year and can amortize the costs of the equipment and engineering over the life of the program. You're paying for multiple tiers of material markup and job shop time on a slow CNC machine that takes time to set up for each part. The OEM parts are cast/stamped and machined/assembled in dedicated equipment that is optimized for speed and cost. No small shop can compete with that for raw price without losing money on the deal.
All that said, that's always a bummer to have something fail so badly.
Old 12-03-2020, 07:55 PM   #6
SirDigby
spins freely: no binding, stuttering, or drag felt
water pump was replaced 20k miles previous.
coolant temp in AM never exceeds 80c; pm never exceeds 85c
pulley temp after 10mi city/15 mi hwy is 69.2F measured with laser thermo.
PULLEY IS GARBAGE!!!
Old 01-03-2021, 12:13 AM   #7
ElMagnifico
Drives: 2012 Sedan
Goddamn . I was just recently thinking about buying the works engineering one. I might have to rethink that.
ElMagnifico is offline   Reply With Quote
Old 01-05-2021, 02:38 AM   #8
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150
Mine is holding up fine(knock on wood), I love it.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
Old 01-08-2021, 04:28 PM   #9
Ronnie V
Drives: 04 3dr HB and 04 5dr RS
Does anyone make a harmonic balancer for the 1nz? I've looked around ATI's site and the 1ZZ is there but no 1NZ
Ronnie V is offline   Reply With Quote
Old 01-12-2021, 01:41 AM   #10
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
If you were on ATIs website you should know better. Its a harmonic damper ;)
Fun fact I worked there like 12 years ago
As far as I know there is no aftermarket damper upgrades for the 1nz, just downgrades.
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 03-03-2025, 01:21 PM   #11
llimonce
Drives: yaris sedan
Very strange , mine water pulley nst broken with 180.000 miles and the crank pulley still running with 240000 miles
llimonce is offline   Reply With Quote
Tags
fail, nst, pulley, water pump
WTS: NST 10% underdrive pully, NST alternator and water pump pulley 47_MasoN_47 Items for Sale by private party 3 05-15-2016 08:53 AM
NST NonStopTuning Pulley Kits NonStopTuning NonStopTuning 19 11-08-2014 11:23 PM
Explain: NST Underdrive & MI pulley evo165 Performance Modifications 14 01-08-2014 03:18 AM
NST (NonStopTuning) Ebay Feedback & Rating NonStopTuning NonStopTuning 0 07-19-2009 11:11 PM
NEW GROUP BUY: NST WP-Lite & ALT-Lite Pulley Kit (NonStopTuning) NonStopTuning NonStopTuning 266 09-29-2007 03:51 AM
