Old 01-03-2014, 01:35 AM   #1
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Explain: NST Underdrive & MI pulley
Hi all,
Currently I am on NST 10% under-drive pulley. I knew that NST have a problem with customer service etc. So far no mechanical problem on me yet.
I just need to know the exact different on the output of the 2 given pulley.
1. NST 10% smaller than OEM pulley size and light.
Since this is 10% smaller in size, It will reduce the engine load by 10%?
2. MI OEM size pulley. I read that this is a tad lighter than the NST 10% UD pulley.
Since this is OEM size, the loading to the engine is the same BUT just a MUCH lighter pulley? Am i correct?
Overall, what does each pulley can make the driver butt feel? Kindly enlighten...
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 01-03-2014, 07:32 AM   #2
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
The 10% smaller pulley will run all your accessories 10% slower thus reducing parasitic drag on the motor. That being said, your water pump, alternator, and a/c compressor are all running slower than factory. There are gains to be had there but not 10%. I know guys that did this in larger trucks and saw a hp or two of increase but they were dynoing 300+ hp.
The fact that it is lightweight means that it is going to rev up faster meaning it will be more responsive. It is the same concept as doing a lightweight flywheel though the difference is not as significance (since you still have that heavy flywheel in there).
I have always heard that the weight difference is a bigger factor than the size. Some cars are very funny about running the accessories too slow (not sure about the yaris though).
I have the MI pulley myself and am happy with it. If I were you, I would leave what I had on there (unless you notice cracks in it... no seriously, check it). I do know that garm put a lot of effort into designing out some of the original flaws of the NST pulleys as they did have issues cracking and breaking. That being said, I have never owned the NST underdrive pulley so I don't have first hand experience.
hopefully this helps. I know there are guys on here that know way more about this than I do but I figured I would throw out a response.
Old 01-03-2014, 09:38 AM   #3
Our pulley maintains OEM size while reducing weight. I like that combination, and I wanted to produce it that way; your accessories all spin according to the way Toyota designed them. Reduced rotational inertia is how you get increased throttle response. "Horsepower" is not the primary benefit of a lighter pulley (or flywheel, same thing but even bigger!)
As Beef says, I have not heard of any cracking or breakage with our design, so I think the changes we made worked.
Old 01-03-2014, 10:09 AM   #4
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
are you running or planning on running forced induction?
Old 01-03-2014, 08:52 PM   #5
evo165
evo165's Avatar
No sir... Currently i am still on NA set-up... Will stick to NA all the way...
I am asking as i need to know if i change from the NST to MI pulley. Will i be downgrading or upgrading due to the fact that NST is smaller therefore less loading to engine & the MI is a tad lighter than the NST pulley... ;)
Old 01-04-2014, 11:41 AM   #6
^ There won't be any noticeable difference; they are both lightweight pulleys. The only difference is in design, and maybe peace of mind. That's an upgrade to my mind.
Old 01-04-2014, 12:05 PM   #7
fnkngrv
fnkngrv's Avatar
Another thing to consider that this point is customer service reachability. I have the under drive pulley from NST. It has worked like a champ for me however in all honesty Mike (NST) is so busy with his business and racing it seems that he has become quite flakey in my opinion. I have called and left him 3 voice mails over the last 2 weeks with no response. Personally if I were you I would pick up the MI item and sell your NST just from a customer support perspective. MI'S shop 9 times out of 10 is pretty responsive on things. If they don't get back to you right away there is usually a solid reason. Not saying Mike doesn't have solid reasons, but his responsiveness has been quite wanting.
Old 01-04-2014, 02:33 PM   #8
Anything we can help you with, Adrian?
Old 01-06-2014, 05:52 PM   #9
fnkngrv
fnkngrv's Avatar
I will hit you up Garm when I have the chance. Thanks.
Old 01-07-2014, 02:47 PM   #10
justjesus
justjesus's Avatar
Drives: 2008 Liftback
My Christmas Card from MI was lost in the mail !
I have been running the NST pulley for about 4.5 years, no problem. I would totally get the MI version, but I'm too damn lazy to do the swap!
Old 01-07-2014, 10:59 PM   #11
tk-421
tk-421's Avatar
Drives: 5D-07-LB
^^ ditto.
Old 01-07-2014, 11:37 PM   #12
Astroman
Modded Moderator
Astroman's Avatar
If my NST pulley ever craps out I'll get the MI version.
Old 01-08-2014, 12:07 AM   #13
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Originally Posted by justjesus View Post
My Christmas Card from MI was lost in the mail ! ...
Hey, what gives... I didn't get a card from MI either!
Old 01-08-2014, 12:17 AM   #14
LOL. Just for fun, we'll do Christmas cards in June this year. Why not, seems like they start playing the music that early now.
Old 01-08-2014, 02:18 AM   #15
evo165
evo165's Avatar
Christmas card? Nope i never receive anything from MI... ;)
NST OEM Lite Crank Pulley or NST 10% Underdrive Crank Pulley 1.5L Tylermayer Performance Modifications 2 06-02-2011 08:03 PM
NST underdrive pulley Group Buy! cali yaris Micro Image 34 03-10-2010 10:50 AM
FS: NST 10% Underdrive Crank Pulley hatchbackkid82 Items for Sale by private party 11 02-26-2010 08:22 AM
NST (NonStopTuning) Ebay Feedback & Rating NonStopTuning NonStopTuning 0 07-19-2009 10:11 PM
Feeler: NST 10% Underdrive Crank Pulley - Gray Black Yaris Items for Sale by private party 10 04-29-2009 11:24 AM
