Old 01-21-2016, 03:13 PM   #127
frankienap
Drives: Yaris 2008 Sedan
I think I'm going to pick up a voltage detector from Lowes tonight. One more question: will I be able to tell which wire coming from the reverse light is positive (versus negative) simply using an analog voltage detector?
frankienap is offline   Reply With Quote
Old 01-21-2016, 09:54 PM   #128
Originally Posted by frankienap View Post
Looking to add power to an aftermarket backup camera. I've searched for over 3 hours for the location of this wire. Here's a picture of the connection for the left rear light assembly on my 2008 Yaris Sedan. Anyone know which wire?
The wires going into the rear lights are: purple, green, orange, white w/a black strip and light blue.
Many many thanks!
If you look at the 12 pin connector which connects to the taillight, the red in pin 5 on the right and brown in pin 5 on the left is reverse.
Old 02-26-2016, 02:55 PM   #129
Gagi
Gagi's Avatar
Drives: Yaris 1.33 vvti 2015
Yes, you can "share" power outlet for that dual USB. I took power from the front one on my Yaris.
Gagi is offline   Reply With Quote
Old 09-17-2017, 08:04 PM   #130
Stabicraft
Drives: 2008 BLACK YARIS
can you please tell me where to take off a 12 volt feed (when the high beam is activated) for my driving lights relay.
Little or no voltage or current required, just power ONLY when high beam is activated.
Thanking you in advance.
Stabicraft is offline   Reply With Quote
Old 11-15-2017, 10:42 PM   #131
Mister-twister
Drives: 2009 Yaris hatchback
People who can share wire schematic/diagram for master windows switch. Look to hookup original master switch to aftermarket power window kit want use original switch instead of one from kit to have auto option.
Mister-twister is offline   Reply With Quote
Old 11-16-2017, 01:27 AM   #132
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
The headlights are earthed to turn on, with permanent 12v power. The simple way is to wire the relay coil across the 2 parallel contacts on the headlight socket.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 02-06-2021, 08:49 AM   #133
rokus
Drives: yaris
Hi,
I have a 2007 yaris hatchback with no daytime running lights.
I bought an aftermarket LED DRL bar, can anyone tell me how to wire it so it switches on after the car starts?
Thanks
rokus is offline   Reply With Quote
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
