![]() Drives: 2009 Toyota Yaris YRS sedan Join Date: Jan 2021
My speedometer is always around 5-8 km slow.
Struggling infront of cameras specially , ended up slowest car in the road since not sure what kind of speed I am driving. Any help on this please ? Thanks in advanced. |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
The response from Toyota will be "this meets Australian Design Rules".
ADRs allow the speedo to read 3 percent plus 4 km/h higher than the actual speed but must not read lower. This is tested at several specified speeds. I have the same error in my Yaris. Interestingly, the data from the OBDii port agrees with GPS speed readings. I have asked a few time on the forum before, but no one seems to have determined if the speedometer has any internal calibration adjustments.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
![]() ![]() Drives: Yaris T1 Join Date: Aug 2020
'Muricah vs Ozstraylyaa...
https://www.youtube.com/watch?v=7n6DEYqVDEY&t=4s https://www.youtube.com/watch?v=XpA57X4Em8Y Who wins?
![]() ![]() ![]() Drives: White '07 3dr LB Join Date: Jun 2016
Only quick fix would be to swap in bigger outer diameter tires to match the speedometer and odometer, at least on the front wheels.
My Michelin Defender in 185/60/R15 actually gives me 3.5% above the speedometer reading while my Gislaved Nordfrost in 175/65/R14 give me 0.5% below reading. I haven't thought about cross referencing the OBDII port with GPS data. What I did was log both GPS speed and distance on a 200km stretch of uninterrupted driving with low traffic to log a constant GPS speed of 100km/h on cruise control along with the GPS odometer and timer and the road side mile markers, and compare to the car odometer reading. So in your case you'd want bigger tires, like a 195/55/R15 instead of a 185/60/R15. You can find data online that would tell you how many revolution per miles or KM your current tire is spec at and use that to determine how many more RPM your bigger tire would need to be to match your speedometer. For example my Michelin Defender was spec at 876 revolutions per miles and the new tire I'm buying this spring is also rated at 876 RPM (BFG Advantage T/A Sport in same size). |
#5 | |
feed my pet
| Tags |
| speedometer, speedometer problem |
| Speedometer issue: Cluster shows 2X true speed w speed limitation at 95 km/h (190km/h | vince90ca | General Yaris / Vitz Discussion | 0 | 02-17-2021 11:45 PM |
| Inaccurate analog speedometer | JudgeM | DIY / Maintenance / Service | 2 | 12-23-2014 06:00 PM |
| Analog Speedometer instead Digital | Sesjusz | DIY / Maintenance / Service | 7 | 07-01-2014 12:42 PM |
| yaris voltage issue | yaris2010RS | DIY / Maintenance / Service | 11 | 12-29-2012 05:20 PM |
