Old 02-04-2015, 12:19 PM   #19
IllusionX
Drives: 07 Yaris Sedan Aero
Is it? So the echo used the c150? Lol I haven't touched this in years. My old memory is failing me. :)
Old 02-04-2015, 12:30 PM   #20
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
Correct! C150 are the Echos 6 bolts
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 02-04-2015, 08:24 PM   #21
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by RagnaCaT View Post
IllusionX you've been around long enough to know that the Yaris USES a C50... And Cranky is almost a master on this subject.
And talking about Frankenstein my trans gets installed today with 1st 3.166 2nd 1.904 3rd 1.310 4th 1.031 5th .815 and a 3.94 final with helical LSD special thanks to Cranky for info and help...
Keep us posted on how it goes this time!
Old 02-16-2015, 12:11 AM   #22
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Cranky car feels great! Still breaking in th clutch but the change of 1st to 2nd and 3rd to 4th is noticible... 300 miles more to go on breakin love the Centerforce Dual Friction the pedal feel its almost ligher thar stock
R-CaT
Project Yar 2ZR
Old 02-16-2015, 09:34 AM   #23
CrankyOldMan
Excellent! Glad I could help. Now if we could just get that 2ZR swap DIY posted... =)
Old 05-23-2021, 03:57 AM   #24
irakli_86
Drives: Yaris MK2
Sorry to pump up the old thread with a question about regearing the 5th on a Yaris.
I've searched the forum but couldn't find the part numbers for the gear set to bring it down to 0.725, just info but no parts number.
I've got the C54 gearbox (according to vin and parts catalogue) on a 2006 1.3 hatchback (couldn't find the final drive ratio either unfortunately anywhere online), correct me if I'm wrong please but are the following part numbers correct for the 0.725 gearing
33428-12100
33036-12120
These seem to be from a 1ZZ engine corolla and should be a direct replacement ?
Thanks
irakli_86 is offline   Reply With Quote
Old 05-24-2021, 11:06 AM   #25
CrankyOldMan
Yes, those are the correct part numbers. Look at Toyodiy.com for which models in your region have those parts. I did the same swap on my C50 build and the shaft journals (diameters) are the same for the 0.815 and 0.725 ratios.
Old 05-24-2021, 06:47 PM   #26
irakli_86
Drives: Yaris MK2
Much appreciated CrankyOldMan, thank you !
One more question, you wouldn't happen to know what final drive ratio my car is on ? Or how I could figure that out (no mention in the manual, parts catalogue, on the casing whatsoever..) ?
Thanks
Old 05-25-2021, 09:35 AM   #27
CrankyOldMan
You're welcome! You may be able to find the part numbers for the ring gear/pinion shaft on toyodiy.com as well if you put in your VIN/plate number. Post them here and I'll see if I can figure it out from that info.
Old 05-26-2021, 04:28 AM   #28
irakli_86
Drives: Yaris MK2
These show up according to VIN :
FRONT DIFFERENTIAL RING GEAR : 41221-12320
FRONT DIFFERENTIAL PINION : 41341-12030
FRONT DIFFERENTIAL SIDE GEAR : 41331-12011
FRONT DIFFERENTIAL PINION, NO.1 SHAFT : 41342-12140
Hope these are the numbers
Old 05-26-2021, 04:08 PM   #29
CrankyOldMan
That ring gear wasn't used in North America, so I can't confirm what ratio it was with my usual methods. I think you'd have to open the case and count the teeth to know for sure. Sorry I couldn't be more helpful.
Old 05-30-2021, 08:26 AM   #30
irakli_86
Drives: Yaris MK2
No worries, you have been a lot of help as it is thank you.
Transmission teardown CrankyOldMan DIY / Maintenance / Service 19 03-04-2015 11:31 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 03:52 PM
5th gear messing up N2scouting DIY / Maintenance / Service 1 09-07-2010 01:39 PM
longer 5th gear german yaris Performance Modifications 36 11-06-2009 12:08 PM
Is using 5th gear at 40mph messes up my engine? Syroyizhka General Yaris / Vitz Discussion 30 04-20-2009 08:59 PM
