![]() Drives: 2009 Yaris S Join Date: Oct 2022
Coil #3 Failed - Replace All or Replace One?
Note: 2009 Yaris is currently at 408K.
After my last episode on 10/21 where my alternator failed and left me stranded until a tow arrived 4.5 hours later, I was faced with yet another issue last night that left me in a similar situation. On the way home from work, the engine started jerking and misfiring, so I immediately put on the hazards and was able to get off of the road and pull into a a nearby Starbucks. I had this happen to me a couple of years ago, which ended up being a failure of coil #2 - so I suspected a similar diagnosis. I requested to be towed to the Firestone near my house. They called me and confirmed that it was indeed a coil failure, this time #3. However, unlike the last time this happened, back when my car was in the high 200s, they are now recommending that all four coils be replaced due to a risk of the others also failing. Am I being ripped off? I mean, the amount of time between this coil failing and the previous coil failing is like....four years. |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Coils are cheap, may as well replace all 4.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
replace 1, parts are cheap but your time isn't, and they don't all fail at once, never
I agree, but it seems to me that it makes actually better sense to replace all at once as it takes just a few more minutes once you are digged under the hood - then you know that you have it all sorted out and it will not fail in the least convenient time (freezing winter outside, summer vacation somewhere, desperate need to drive a relative with broken ankle to a hospital...) to spoil your situation.
On a related note - can the coil actually get worn-out to a fact that it impacts the engine performance but does not produce an error code?
My 2007 64kW engine with 205000 km (original coils) is running realiably but it is just not as "live" as it used to be. Compression is ok. New iridium plugs helped a bit but the feeling is still a lot worse comparing to another similar Yaris I recently drove (same engine). Regularly changing fluids, filters... |
Next time you get a P00123 or four don’t bring it to the dealer just swap the coils around to find the bad one do it yourself.
Yep, a code reader and a spare coil is one thing I keep in the car.
Gen 3 > Gen 2
Its literally a 5 minute job to replace all 4 on a 1NZ-FE lol
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
i like using oem coils, aftermarket ones dont have good contact on the bottom boots that grip the spark plug, just buy 1 at a time, and buy OEM coils
| ABS sensor replace without hub | zrwon | DIY / Maintenance / Service | 9 | 10-12-2018 06:06 AM |
| Should I replace the motor mounts? | BennyLava | General Yaris / Vitz Discussion | 5 | 11-06-2017 08:32 AM |
| 2008 Yaris - replace key ignition with keyless (push button) start | jefflunt | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 11-20-2016 05:28 PM |
| Time to replace rotors. Which brake upgrades? | BennyLava | DIY / Maintenance / Service | 25 | 05-16-2016 05:57 PM |
| did autolite spark plugs screw up coil or coils ?? | la_scanner | DIY / Maintenance / Service | 20 | 04-09-2009 02:07 PM |
