Old 11-05-2017, 12:21 AM   #1
BennyLava
Drives: 1987 Silverado
Should I replace the motor mounts?
Hi all. I have a 2009 Yaris sedan. It is coming up on 200k miles on the odometer. I was wondering if that is considered a time, when it would be a good idea to replace the motor mounts. It seems to me that 200,000 miles would probably take its toll on the engine mounts.
If not, is there a known interval for changing the mounts? After all they are a consumable part, they do wear out. And I'm someone who likes to replace things at the interval, so I get a chance to replace them before they break and cause me problems.
BennyLava is offline   Reply With Quote
Old 11-05-2017, 08:06 AM   #2
MT or Auto?
Old 11-05-2017, 10:25 AM   #3
BennyLava
Oh sorry yeah its an automatic.
Old 11-05-2017, 10:44 AM   #4
I wouldn't worry about it unless they actually break which is highly unlikely. The load on the mounts with an auto are fairly constant.
Old 11-05-2017, 10:55 PM   #5
BennyLava
Yeah but the rubber bushing should wear out eventually. Or at least get to where its getting a good bit thinner that it is supposed to be. Maybe that doesn't happen till 300k
Old 11-06-2017, 08:32 AM   #6
dogsridewith
Drives: 2007 2-door hatchback
Clutch chatter motor mounts ?
I only get clutch chatter w/ manual transmission when backing up. Any possibility this points to engine mounts as a problem? prolly 142k miles on everything.
Time to replace rotors. Which brake upgrades? BennyLava DIY / Maintenance / Service 25 05-16-2016 05:57 PM
Replace 2008 Yaris D4 sedan passenger side window harvey DIY / Maintenance / Service 0 08-01-2015 02:53 PM
LEDs to replace interior lights: Which ones? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 57 04-28-2010 01:44 PM
