Old 11-22-2022, 11:38 AM   #1
HDS
Drives: 07 Yaris, Saab 900 Turbo
Anyone mounted LED Ramps or extra headlights?
Mainly interested in 05-09 models. I've not found any examples online and I was considering adding extra lights on the front, or a led ramp to my yaris. I would have liked to have seen what it would look like before attempting it.
I live near the arctic circle and drive a lot on roads without lightning, so some extra full beams would be nice.
HDS is offline   Reply With Quote
Old 11-22-2022, 11:52 AM   #2
sh0rtlife
i did a mod on mine im running the "spec D" on the 07
however i went a lil nutty with modifying how the lighting works
step 1 this alone makes a MASSIVE differance and will light up all the "holes"
add factory fog lights GLASS units, then toss a Innovited 55W AC HID in the 6000k to 8000k range
next do the same for the low beam and the high beam
at that point youve got ALOT of light comming off the front...however i took it 1 step further and added a 4th relay so that when i hit the high beams the low beams dont shut off so i get ALL THE LIGHT
i typicaly run around with just the marker lights on and the fogs, when its really dark n rainy the headligths come on...get out into the woods and the highs go on and you can litteraly see everything in all directions for miles
the high low mod for 4 lights on makes a HUGE differance..as if the HID's didnt in the first place...
and i do swear by that brand..inexpensive friendly customer service thats on top of helping you ASAP even if they need to send you a bulb or a wiring harness free of charge...as i had a high low switch box die on my explorer(new style) and they sent me out the old style in a complete harness to fix the issue...
Old 11-22-2022, 10:15 PM   #3
Compeer
Drives: NCP90 TRD Yaris Manual
Has anyone tried the cheap ebay/amazon led headlights? People said quality was not that great but that they did work and seemed way brighter.
theres this style https://www.ebay.com/itm/31416811960...Cclp%3A2047675
and this one https://www.ebay.com/itm/35430595274...Cclp%3A2563228
Compeer is offline   Reply With Quote
Old 11-23-2022, 01:56 AM   #4
sh0rtlife
thats them, the ones i ended up with turned out to be genuine spec d
https://www.ebay.com/itm/314003439942
yes thats the "smoked" version but i bet if mine were genuine that if that seller has the clear ones they are probably also genuine spec D
the only real issues ive noted with them is when switching to HID youll need to "tweak" the mounting to have a little more "bite" on the bulbs otherwise the only real issue is that the small 3 led's up the sides will likely need a dab of RTV on them to keep them from bouncing out and the "halos" arnt very bright...both simple fixes
honestly the stock light lenses on our OE lights were so bad that even with the supplyed shit bulbs in the spec d's it was a massive improvement..adding the HID's was leaps and bounds beyond that
Old 11-24-2022, 01:10 AM   #5
HDS
I bought a set of Hella FF500 lights.
e:
Lighting rules are strict here BTW. I am not allowed to modify my normal H4 lamps and any lamps mounted must be approved for road usage. I can mount up to three extra lights in front, or a led ramp.
Old 11-24-2022, 01:50 AM   #6
HDS
It will probably look like this. Couldn't find a yaris with extra lights, so an auris will have to do.
Old 11-24-2022, 07:53 AM   #7
Flubby
Drives: 2015 Yaris
I like these dark smoke styled ones
Flubby is offline   Reply With Quote
Old 11-24-2022, 01:52 PM   #8
sh0rtlife
e:
FWIW HID's were/are an option on the yaris, so you might be able to skirt the laws on that
Old 11-24-2022, 01:54 PM   #9
sh0rtlife
the link ii posted are smoked ones and turned out to be geniuine spec d's ...the smoke in the listings shows darker than it really is
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
DIY LED Strip under the door panel charleschia1986 DIY / Maintenance / Service 19 11-05-2011 07:49 PM
Where to get Sedan Projector Headlights and Led Tails c4c Cosmetic Modifications (Exterior/Interior) 1 05-19-2009 12:38 AM
Hella Headlights and LED washer nozzles spkrman Photo-Video-Media Gallery 8 04-18-2007 10:54 PM
