Old 05-23-2020, 03:34 PM   #1
SoWeird
Drives: Yaris Hybrid 2017
Arrow DRL lights not working - help needed
Hello guys,
I have a 2017 Yaris Hybrid (hatch) with DRL lights that are almost non visible. Only when i get close to them i can see a dim light coming out of them.
This issue is on both sides (driver and passenger).
I`ve asked a mechanic to check the cars` battery, and it checked out fine.
Then i asked to get a quote on fixing the DRL lights, hoping it would be a cheap option of just unscrewing a light bulb and putting a new one in...
The mechanic said that it will require the whole front assembly to be removed and gave me a very large price quote on the parts+job.
Is there any way to replace the DRL (LED) lights on it without throwing away the entire assembly?
My front low beam lights and the motor and the case itself are working fine and i would hate to pay large sums of money just to replace a few LED`s.
P.S. The picture is just an example, not my actual car.
Thank you for your assistance.
SoWeird is offline   Reply With Quote
Old 06-11-2020, 06:54 AM   #2
pribek
Drives: Man
Send a message via ICQ to pribek Send a message via AIM to pribek Send a message via Yahoo to pribek
DRL problem
Try releasing the parking brake and moving a few feet.
I don’t know why but on my Yaris it helped, the DRLs turned on.
pribek is offline   Reply With Quote
Old 06-11-2020, 01:58 PM   #3
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
Yes you have to loosen the handbrake before they turn on.
But not all trim levels has LED stribes DRL, but only old style glow bulb like this.
On this one its just crome stribes instead of LED stribes.
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Old 07-21-2021, 07:27 AM   #4
majoroson
majoroson's Avatar
Drives: Toyota Yaris
There are many different flashlights. I often do not understand some essence in them. There are so many flashlights, and each one is different. Different colors, shapes or glass. I often use them myself, since I recently fell down the stairs in the dark and broke my leg. My friends say that my flashlight is not very effective. I'm trying to test the effectiveness of flashlights myself, but there are so many of them ... I used a lot of flashlights, but one struck me. Have you ever seen many functions in one flashlight? This flashlight can do a lot, you just have a look thegrommet.com and you will like it.
majoroson is offline   Reply With Quote
Old 08-11-2021, 08:33 AM   #5
Yaris 2017
Drives: Yaris Premium 2017
Hi! I have also 2017 yaris and problem also with drl. i ask from toyota and price is 550 eur / each
Both sides part on light works fine but not all...
Yaris 2017 is offline   Reply With Quote
Old 10-03-2021, 12:27 PM   #6
scupell
Drives: Yaris Hybrid active 2017
Hello Everybody.
I'm Italian, I bought a yaris Hybrid in December the 2017, and just a month ago, I've got the same problem with a DRL in a frontlight that is almost died emetting just a small umpercettible light. I'm interested How many in the world have caught the same expensive issue and if does it exist a way to have the light substituited by Toyota without paying like to buy a new car. THX
scupell is offline   Reply With Quote
Old 08-02-2023, 07:18 AM   #7
s91m
Drives: Yaris Feel! 2017
Question Same dimmed DRL issue - Toyota Yaris 2017
Hello everyone,
Question: have you or anyone else found a solution to this issue? I'm having the same problem in my Yaris Feel! 2017. I don't want to replace the full set just because of the LEDs, but at the same time I don't know how to fix this kind of problem.
Thank you in advance
s91m
s91m is offline   Reply With Quote
Old 06-01-2025, 12:45 PM   #8
Zse4444
Drives: Toyota Yaris Hybrid 2018
Hi all! I'm experiencing the same issue. I tried to fix it, but I couldn't disassemble it because it's glued on. I haven't tried heat. It's as if the LED faded due to the heat or fell out of the acrylic casting that holds the light.
Zse4444 is offline   Reply With Quote
Old 06-05-2025, 10:49 AM   #9
Zse4444
I disassembled the headlight with a heat gun; it went very easily. Because anywhere it is found, the only problem with the "lamp" is that the heat from the LED melted the acrylic part, which spread the one LED's light. And yes, it was the problem. Easy task to clear the led, and cut a few mm back the acrylic part, polish back to clear. However, unfortunately, the "good" LED for the lower light strip also goes bad in the meantime. Perhaps due to static electricity or some other factor. Anyone see, or get somewhere this type of LED? It's 6×8 mm.
3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation keiri Third Gen Yaris General Discussion 26 09-04-2020 01:01 AM
Dashboard lights and exterior park lights going off NXyaris Suggestions - Feedback - Questions 2 09-09-2016 05:46 PM
Relay Wiring for DIY LED Daytime Running Lights (DRL) zuberio DIY / Maintenance / Service 20 07-07-2011 09:02 PM
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 06:13 PM
RS Lights .... reflector needed... YAR1S General Yaris / Vitz Discussion 8 03-13-2009 05:41 PM
