Old 06-21-2007, 01:34 PM   #1
jeff69dini
Drives: 2007 Yaris Sedan 4 Door
any thoughts? btw, do these little engines have any kind of relief to let out "extra" oil pressure or oil? just a weird thought....lol
jeff69dini is offline   Reply With Quote
Old 06-21-2007, 02:53 PM   #2
Toyotech
Your Toyota Technician
Drives: 06 Cobalt SS/SC, 06 Rolla S
Send a message via AIM to Toyotech
many little outlets where leaks occur...could be a manufacture defect. by corner do u mean at the valve cover?...extra oil will go through the pcv and puddle into the manifold in most cases
Toyotech is offline   Reply With Quote
Old 06-21-2007, 04:15 PM   #3
jeff69dini
ok I hope I can explain this better....
standing in front of car with the hood up....by corner, then I mean the left side at the back of the engine ~ half ways down...,the engine block is sorta sculpted into a little square piece where anything, oil, water, etc can pool.....if it helps, it looks like the piece of metal in front of it has a ball bearing in it....hard to describe, sorry......anyways I found some oil in this little "square piece"......only place I could see it being from was a seal...
Jeff
Old 06-21-2007, 05:36 PM   #4
punch
punch's Avatar
Drives: 2007 Yaris Sedan "D" package
Jeff
no you don't have to worry, probably from the manufaturer or the last person who did an oil change...the oil isn't under pressure so don't worry.
punch is offline   Reply With Quote
How many bottles of engine oil do you add? hans_fh General Yaris / Vitz Discussion 23 05-27-2007 08:59 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
About Engine Oil Changing Manual hans_fh DIY / Maintenance / Service 4 03-03-2007 10:20 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
