Old 06-27-2007, 05:48 AM   #1
Consider it homework.. though you're not even in my class???
A question, though, instead of wiring all the way to the front headlight for the parking light signal, could you not connect them to illumination wires in the cabin somewhere? For example, I have power windows, and on the driver's side, the AUTO text on the switch is illuminated whenever the headlights are on, and I was thinking to tap into that wire, and find a similar one on the passenger side. Whaddaya think?
Old 06-27-2007, 09:14 AM   #2
redyaris
Shiny Chromey Coolness
redyaris's Avatar
etimago that might be your shortest wire route but I wouldn't want to risk blowing a fuse or taking out a switch light that would later need to be replaced. Also wouldnt want the mirror LEDs to blink when I was lowering my power window!
Im a simple man and I did what I thought was the easiest, most direct wiring (to the wire source I knew I needed). No pulling trim pieces either and routing wire in the cabin.
Yarisworld.com DIY Manual v3 vodkalush DIY / Maintenance / Service 101 06-25-2024 12:10 AM
"Official" Yarisworld.com DIY Manual vodkalush DIY / Maintenance / Service 41 11-02-2023 11:47 PM
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Replacing stock deck - photo tutorial gravylegs In Car Entertainment + Electronics (audio / video / alarm) 39 02-06-2012 01:04 PM
replacing stock rims after the winter mikeukrainetz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-24-2007 09:36 AM
