Old 06-27-2007, 06:29 AM   #1
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
Thanks for the write up. It will make it a little easier for us that got our mirror covers through the recent Thai group buy.
I can't really picture how you routed the wires though. Did you fish them through the boot with the rest of the wires from the door and then out through the firewall or what?
Old 06-27-2007, 09:26 AM   #2
redyaris
Shiny Chromey Coolness
redyaris's Avatar
Sorry about that, I should have taken more detailed pics of the wire routing....
Violin I ran the 3 mirror wires (blue/white/black) from an interior access hole from the mirror mounting on the interior door panel, ran them up and under the top trim piece of the door arm rest, wrapped the wire around the corner of the door (I could have drilled an access hole but im lazy), and put the door panel back on to hold the wire. I then tucked the 3 wires under the rubber weatherstrip. I also put a couple of pieces of sticky black duct tape to hold the wires to the door to prevent pinching when opening and closing.
I connected my extension wire then to all 3 mirror wires. I ran these 3 extensions into the engine bay and side marker lamps on each side by tucking them under the big black triangular trim piece directly in front of the mirror (no need to remove it even). (If you pry it up a little from the bottom youll see the fender area and the side marker lamp).
I was able to reach my manly arm into the fender area from the front of the car to grab the extension wire and fish it to the side marker lamp and into the engine bay for connection to parking lamps and ground bolts.
Its surely NOT factory but it works....and if anyone opens my door to look at wires they are anal.
Yarisworld.com DIY Manual v3 vodkalush DIY / Maintenance / Service 101 06-25-2024 12:10 AM
"Official" Yarisworld.com DIY Manual vodkalush DIY / Maintenance / Service 41 11-02-2023 11:47 PM
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 09:15 PM
Replacing stock deck - photo tutorial gravylegs In Car Entertainment + Electronics (audio / video / alarm) 39 02-06-2012 01:04 PM
replacing stock rims after the winter mikeukrainetz Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 02-24-2007 09:36 AM
