Old 06-27-2007, 01:14 PM   #1
steved
Yaris Rules!!
Drives: 2007 Red Yaris Liftback a/t
Originally Posted by Geelmeel View Post
I wanted to check at what mileage do brakes usually get replaced? I have 15000 miles on my Yaris and today I heard the brakes squeak for the first time. I want to see if this is normal. I am going to be taking it in for the 15000 mile service and when I tell them I don't want them to just replace the brakes to screw me. Thanks for your help.
Does it squeak all the time or when it is hot outside?
I haven't had this problem on my yaris yet (just got it), but this happened alot on my echo sedan when it is hot outside. Even after changing the pads on rotors. The only thing that help this was adding a little bit of brake grease to the back of the pads.
The squeak is likely comming when the brake caliper piston puts pressure on the pad, not worn out pads.
steved is offline   Reply With Quote
Old 06-27-2007, 07:09 PM   #2
ECHOKnight2000
Small Car Lover
ECHOKnight2000's Avatar
Drives: A Super Car
My ECHO started it as well. Only when I'm like backing up in a driveway. Or driving slowly but its mostly when I back out. I think its when I don't fully put the breaks on. Its embarasing but I hope they last for awhile. I'm a little over 46k so they should last a little longer. How many miles did you have on your ECHO when you replaced the brakes?
You may look good on the beach but in reality you're a pompus, egotistical jerk. "I was never on the beach with you..."and you never will.
ECHOKnight2000 is offline   Reply With Quote
Old 06-28-2007, 07:58 AM   #3
steved
Yaris Rules!!
My did it also when driving slowly in traffic. Put brake grease on the bake of your pads should help the problem.
I change my brakes the first time at 102 kilometers secound time at 190 kilometers and now at 254 kilometers and the brakes are still good. And it is an automatic.
Old 06-28-2007, 05:47 PM   #4
Edd
Drives: None
Whoa! What have you done to your brakes, they really should last 500-1000 times more than that.
Edd is offline   Reply With Quote
Old 06-28-2007, 07:59 PM   #5
ECHOKnight2000
Small Car Lover
Drives: A Super Car
Thanks Steved for the info.
brakes - how may km. Rabbit General Yaris / Vitz Discussion 9 05-28-2007 11:35 PM
Brakes and Shocks question jamal1984 DIY / Maintenance / Service 6 03-18-2007 04:26 PM
Brakes question MeggiemobileSFLA DIY / Maintenance / Service 23 03-16-2007 05:17 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
Brakes jcove Performance Modifications 4 05-03-2006 11:59 AM
