Old 06-27-2007, 01:14 PM   #7
steved
Yaris Rules!!
Drives: 2007 Red Yaris Liftback a/t
Originally Posted by Geelmeel View Post
I wanted to check at what mileage do brakes usually get replaced? I have 15000 miles on my Yaris and today I heard the brakes squeak for the first time. I want to see if this is normal. I am going to be taking it in for the 15000 mile service and when I tell them I don't want them to just replace the brakes to screw me. Thanks for your help.
Does it squeak all the time or when it is hot outside?
I haven't had this problem on my yaris yet (just got it), but this happened alot on my echo sedan when it is hot outside. Even after changing the pads on rotors. The only thing that help this was adding a little bit of brake grease to the back of the pads.
The squeak is likely comming when the brake caliper piston puts pressure on the pad, not worn out pads.
steved is offline   Reply With Quote
brakes - how may km. Rabbit General Yaris / Vitz Discussion 9 05-28-2007 11:35 PM
Brakes and Shocks question jamal1984 DIY / Maintenance / Service 6 03-18-2007 04:26 PM
Brakes question MeggiemobileSFLA DIY / Maintenance / Service 23 03-16-2007 05:17 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
Brakes jcove Performance Modifications 4 05-03-2006 11:59 AM
