Old 06-28-2007, 06:56 PM   #13
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
Originally Posted by nsmitchell View Post
Whatever you do, get Genuine Toyota pads or you will squeaking forever, no matter how much anti-squeal compound you apply. Never put cheap pads on Hondas or Toyotas!
i can back that up. if you want quiet and dependable, go oem. if you want performance or cheapy breaks then squeaks are going to happen, esp. any time it rains. squeaks dont always mean they are worn. sometimes humidity or road debris can cause it. actually waiting for them to start making noise isnt smart. in most instances when the pads wear down to the warning tang there is usually only about 2mm or less of the pad lining left. best to check them out every once and a while, it will save you from having to pay for rotors to be cut or replaced too. since brakes arent warrantied, get whats best. simple as that.
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
brakes - how may km. Rabbit General Yaris / Vitz Discussion 9 05-28-2007 11:35 PM
Brakes and Shocks question jamal1984 DIY / Maintenance / Service 6 03-18-2007 04:26 PM
Brakes question MeggiemobileSFLA DIY / Maintenance / Service 23 03-16-2007 05:17 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
Brakes jcove Performance Modifications 4 05-03-2006 11:59 AM
