Old 06-28-2007, 09:49 AM   #1
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Originally Posted by Geelmeel View Post
I wanted to check at what mileage do brakes usually get replaced? I have 15000 miles on my Yaris and today I heard the brakes squeak for the first time. I want to see if this is normal. I am going to be taking it in for the 15000 mile service and when I tell them I don't want them to just replace the brakes to screw me. Thanks for your help.
Whatever you do, get Genuine Toyota pads or you will squeaking forever, no matter how much anti-squeal compound you apply. Never put cheap pads on Hondas or Toyotas!
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 06-28-2007, 06:56 PM   #2
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
i can back that up. if you want quiet and dependable, go oem. if you want performance or cheapy breaks then squeaks are going to happen, esp. any time it rains. squeaks dont always mean they are worn. sometimes humidity or road debris can cause it. actually waiting for them to start making noise isnt smart. in most instances when the pads wear down to the warning tang there is usually only about 2mm or less of the pad lining left. best to check them out every once and a while, it will save you from having to pay for rotors to be cut or replaced too. since brakes arent warrantied, get whats best. simple as that.
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Old 06-28-2007, 07:03 PM   #3
jamal1984
The Beautification of Car
Drives: Toyota Yaris S
Send a message via MSN to jamal1984
My brake squeaks when it's rains. And i only got 25k miles. Original Toyota Brake Pads.
I took it back to dealers and they gave me some bullshit answer like you have to upgrade to Drill/Slot BRAKE ROTORS + Performance pads to stop squeaking.
I mean do Drill/Slot BRAKE ROTORS worst it? if yes then i will go ahead and upgrade my.
jamal1984 is offline   Reply With Quote
Old 06-29-2007, 12:51 AM   #4
drifto
drifto's Avatar
lol thats a crazy dealership man. brakes squeak sometimes like i said. it doesnt always mean there is a problem. performance pads usually squeak more b/c the fricion material used is meant to withstand heat better. oh and to say you need slotted/drilled rotors to solve the problem is hillarious. usually high performance pads have more metal composition causing more squeaks. after it rains most cars will squeak for a bit till the rotor and pad surface dry up. it will happen after a car wash too somtimes, so dont stress it.
07 Yaris LB 5spd
brakes - how may km. Rabbit General Yaris / Vitz Discussion 9 05-28-2007 11:35 PM
Brakes and Shocks question jamal1984 DIY / Maintenance / Service 6 03-18-2007 04:26 PM
Brakes question MeggiemobileSFLA DIY / Maintenance / Service 23 03-16-2007 05:17 PM
Changing drum brakes to discs? eTiMaGo Performance Modifications 5 09-25-2006 04:17 PM
Brakes jcove Performance Modifications 4 05-03-2006 11:59 AM
