i can back that up. if you want quiet and dependable, go oem. if you want performance or cheapy breaks then squeaks are going to happen, esp. any time it rains. squeaks dont always mean they are worn. sometimes humidity or road debris can cause it. actually waiting for them to start making noise isnt smart. in most instances when the pads wear down to the warning tang there is usually only about 2mm or less of the pad lining left. best to check them out every once and a while, it will save you from having to pay for rotors to be cut or replaced too. since brakes arent warrantied, get whats best. simple as that.
07 Yaris LB 5spd AE86 Corolla GTS 5spd http://microimage.ning.com/ http://www.microimageonline.com/store.html |
#2 | |
The Beautification of Car
I took it back to dealers and they gave me some bullshit answer like you have to upgrade to Drill/Slot BRAKE ROTORS + Performance pads to stop squeaking. I mean do Drill/Slot BRAKE ROTORS worst it? if yes then i will go ahead and upgrade my. |
#3 | |
| brakes - how may km. | Rabbit | General Yaris / Vitz Discussion | 9 | 05-28-2007 11:35 PM |
| Brakes and Shocks question | jamal1984 | DIY / Maintenance / Service | 6 | 03-18-2007 04:26 PM |
| Brakes question | MeggiemobileSFLA | DIY / Maintenance / Service | 23 | 03-16-2007 05:17 PM |
| Changing drum brakes to discs? | eTiMaGo | Performance Modifications | 5 | 09-25-2006 04:17 PM |
| Brakes | jcove | Performance Modifications | 4 | 05-03-2006 11:59 AM |
