Old 07-02-2007, 11:26 PM   #1
nigel
Drives: yaris
http://www.28car.com/acc_dsp.php?h_i...&h_mb_id=83930
will that work on yaris?
its for echo ncp10
nigel is offline   Reply With Quote
Old 07-03-2007, 01:11 AM   #2
Biggie™
Biggie™'s Avatar
Drives: '07 3 Door Yaris of Doom!
its for echo ncp10
There you go, for all those wanting to say they have a 4-2-1 header on their Yaris... 5Zigen
But there's a problem. On a proper 4-2-1 header design, the length of the primaries(tubes coming of the head) need to be far longer then they can be with the current Yaris design. With the limited distance/available space the headers were given, a 4-2-1 header will more than likely not be of as much benefit when compared to a 4-1 OEM/TRD style header.
Just remember... It isn't a coincidence that both the stock Toyota header and the TRD performance header are a 4-1 design.
Biggie™ is offline   Reply With Quote
Old 07-03-2007, 01:45 PM   #3
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I agree on this point. The 5Zigen (even if you could get it to fit the yaris, which it wont) is not a true 4-2-1 header. That Zigen looks almost like a hybrid 4-1/4-2-1. The header tubes need to be a certain length to get the most power possible out of the header. This length is going to be different on every car. There's no advantage in having a 4-2-1 header, or any header for that matter, if the primaries (and secondaries) aren't tuned to the proper length. This is why the megan header sucks, IMO. They simply replicated the stock header configuration with a larger diameter tubing. Even a 4-1 header needs tuning and header tuning requires R&D and at least an experienced header builder who knows the effects of primary and secondary tube lengths and what collector configuration(s) to use. Replication of the stock header brings no benifits in the scavenging department, only more air flow. The primaries need to be longer in order to better scavenge exhaust gases. This is the benefit of having the 4-2-1 and as I've said in other threads, there just isn't enough space between the stock header and the exhaust flange to make a true bolt-on 4-2-1. So yeah biggie, I think you're right on. This is why WeaponR hasn't released their 4-2-1 yet. They've had more than enough time. To put a header on this car that actually makes power, the whole exhaust system needs to be replaced. And btw, if any of you vendors are going to offer a full system with cat... please please let me be your guinea pig!!
Galavoxx is offline   Reply With Quote
MEGAN HEADERS! < group buy price! C2AUTOSPL Sponsors Classifieds Area 20 09-17-2007 01:54 PM
Headers Rabbit General Yaris / Vitz Discussion 1 05-20-2007 12:10 PM
Fuel Level Gauge Stuck ? - 2007 Yaris Sedan kaboom New YARIS Purchase Forum 9 05-15-2007 02:58 AM
Automatic Choke Stuck Rua General Yaris / Vitz Discussion 9 02-22-2007 06:57 PM
Exhaust Headers. Worth it? OgDogg Performance Modifications 4 12-31-2006 09:14 PM
