Old 02-07-2007, 05:20 AM   #1
Rua
Drives: 2002 Vitz Automatic
Question Automatic Choke Stuck
I have an 2002 Automatic Vitz and it is reving high when starting. I believe the automatic choke is stuck in the on position. Can anyone tell me where the automatic choke is located and how to adjust it.
Rua is offline   Reply With Quote
Old 02-07-2007, 06:39 AM   #2
bugnuts
bugnuts's Avatar
Drives: 2007 Yaris Liftback BBP
Does the idle keep going up and down after it starts to warm up a bit? Toyota used a valve in the past on some of the vehicles that would cause this problem, It is linked into the cooling system.
"I am un chien andalusia" - Black Francis
bugnuts is offline   Reply With Quote
Old 02-09-2007, 12:02 AM   #3
swng
swng's Avatar
Drives: 06 3-dr auto RS
I believe that there is a good chance that the car's computer is, among its many functions, doing the duties of a choke. You may be experiencing a problem not related to a choke in the traditional sense.
Wish you can solve the problem soon!
swng is offline   Reply With Quote
Old 02-09-2007, 02:28 AM   #4
pennystocks
pennystocks's Avatar
Drives: 07 Civic Si Coupe(Black Pearl)
Choke? I think those went out of style round the same time as billy idol
Yea sounds like a computer problem, is the check engine light on? First thing i'd do is scan the comp for codes.
pennystocks is offline   Reply With Quote
Old 02-09-2007, 04:00 AM   #5
It's normal for it to rev high at first, and gradually settle down, just part of the automated warming up process
Old 02-09-2007, 11:13 PM   #6
nick1983
nick1983's Avatar
Drives: 2007 Toyota Yaris sedan
How do you scan codes? I want to know how.
nick1983 is offline   Reply With Quote
Old 02-10-2007, 05:31 AM   #7
pennystocks
How high is it revving?
You can buy a scangauge @ scangauge.com, awesome product or go a mechanic or something.
Old 02-10-2007, 07:13 AM   #8
spkrman
Drives: 1
most mechanics charge you.
autozone and the like will scan for free :)
Old 02-20-2007, 02:48 AM   #9
bob_cougar
Drives: toyota 07 yaris
That's what I like about about autozone as they give you a free scan. You can use the money you have saved for the services of mechanics in case you need one.
________________
Toyota 07 Yaris - Get the Toyota 07 Yaris Catalog by Toyota Motors
bob_cougar is offline   Reply With Quote
Old 02-22-2007, 06:57 PM   #10
Moose
Resident Redneck
Moose's Avatar
Drives: 07 Polar White Yaris Sedan 5M
If there isn't a check engine light on, then a scan tool (like the ones at AutoZone) will not help you.
Besides, guys, I don't think there are any AutoZones in Ireland.
If it doesn't go away after the vehicle is warm, then it sounds like an idle air control valve to me. I see them everyday. It may just need to be cleaned out- I'm not sure if yours is on top of or under the intake manifold- wherever it is, pull it out, spray carb cleaner through it until the carbon buildup is gone, and re-install. If the problem persists, contact your Toyota dealer. They, and only they, have a new computer (just released to dealerships) that can pull a history and health check- it pulls all codes and diagnostic information stored in your ECU. At that point they can make a determination as to what is wrong- even if there is not a check engine light on.
My other rides:
2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon!
1999 Honda Civic EX Coupe 5M w/ B18 powaa
1985 Toyota Celica GTS Coupe 5M- track whip
http://www.importlounge.com
Moose is offline   Reply With Quote
5spd vs automatic m-arco General Yaris / Vitz Discussion 16 12-14-2006 05:32 PM
Is that bad for automatic transmission? hans_fh General Yaris / Vitz Discussion 9 11-20-2006 07:25 AM
Automatic LB w/CP in FL?? Placebo New YARIS Purchase Forum 7 10-29-2006 10:50 PM
Manual vs. Automatic ?? YarisBlazer General Yaris / Vitz Discussion 12 08-13-2006 07:14 PM
Shift Knob for automatic noodles009 Cosmetic Modifications (Exterior/Interior) 13 07-28-2006 05:18 PM
