Old 07-03-2007, 04:15 PM   #1
WRBlue
Drives: Yaris 3 Door, 04 WRX, 69 Lotus
Originally Posted by hans_fh View Post
I JUST CALLED THE SALESPERSON TONIGHT, HE TOLD ME UTAH IS ON HIGHER SEA LEVEL SO THAT 85 IS FINE FOR MOST OF CARS. HE IS BS!!! ANYWAY I WILL SWITCH TO 91 AT CHEVRON TOMORROW.
He's right. At higher elevations, an engine needs less octane fuel to prevent knock. It has to do with the lower density. Thats also why you can't compare quartermile times at different elevations.
You're probally getting knock because of the summer heat. Hot air explodes easier than cooler air. Thats why You run richer in the winter and leaner in the summer - but the computer corrects for it. Also thats why carbs need to be retuned every season to run the best.
WRBlue is offline   Reply With Quote
Old 07-03-2007, 07:47 PM   #2
Pars
Drives: 07 Yaris Liftback
True, I usually run with regulars gas (which is 87 Octane), but if a heat wave is coming, I'll switch to Premium to help the engine run as cool as possible (engine knocking does generate extra heat).
I haven't notice any real advantages with performance (premium vs regular), however on occasion, the engine will feel a little more sluggish then usual, but those isolate occurrence only happen when I'm running on regular gas (probably caused by a bad batch gas, with octane level lower then the required 87).
Pars is offline   Reply With Quote
Old 07-04-2007, 12:29 AM   #3
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
He's right. At higher elevations, an engine needs less octane fuel to prevent knock. ........
Haven't heard that one before????? Who told you that?????
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
engine question... (2ZR-FE and 2ZZ-GE) Avia General Yaris / Vitz Discussion 5 12-24-2010 08:16 AM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Engine bay prettification project eTiMaGo Cosmetic Modifications (Exterior/Interior) 14 04-23-2007 04:22 PM
wtb 1nzfe engine blown or working turboyaris Items for Sale by private party 5 04-08-2007 02:03 PM
higher octane fuel KSIbucky DIY / Maintenance / Service 37 01-14-2007 07:17 PM
