Old 07-07-2007, 12:36 AM   #1
toyota-belta
Drives: toyota belta s importer
Originally Posted by Violin View Post
Here we go:
I took my speakers out and ran the wires down through the door
and fed it through the boot into the cabin
On the passengers side I ran the wire through the firewall using the grommet for the rear window washer hose
On the drivers side, I jacked up the car to get access to where the hood latch runs through
In ran just the power wire for the blinker through (red) into the engine compartment.. The ground (black) was grounded inside the cabin. I crimped a ring terminal on the ground wires
To access the blinker circuits, I popped the top of the bumper off and removed both headlights. There is a bundle of wires running under each from inside the fender. The driver's side power wire was hooked to the smaller green striped wire here
Like so
and the passenger's side goes to the green wire here
Like so
I decided not to use the white LEDs (gray wire) as I don't know if its legal to have white running lights on your mirrors here. I may hook them up so I can switch them on/off at will.
Here's a video clip of the blinker in operation:
click to watch
Movie clip - click to watch
my file is to pass everywhere ok I would like to know or that I connect the wire
toyota-belta is offline   Reply With Quote
Old 07-07-2007, 08:51 AM   #2
the_boss
the_boss's Avatar
Drives: 07 YARIS HATCH 5 DOOR
Send a message via MSN to the_boss
dit moi ses quoi tu veut luis demander et je vais luis traduire!
(tell me what you want to say and Ill translate it!)
the_boss is offline   Reply With Quote
Old 07-07-2007, 12:19 PM   #3
toyota-belta
bonjour je voudrais savoir ou me brancher pour que mes cover marche avec mes flocher merci
toute mes file sont passer de la porte il me reste a me connecter
merci beaucoup
Old 07-07-2007, 12:53 PM   #4
the_boss
the_boss's Avatar
merci beaucoup
Hey Violin, this guy would like to know where to take the power to have his signal light flashing with his reg, flasher. Everything is ready but he need to know where to tap to get the juice!
Hope you understand what I mean !!
thanks
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY: Strut Tower Brace Bar redyaris DIY / Maintenance / Service 18 03-16-2014 06:52 PM
DIY: Yaris LB Halo Led Projector Headlights goku87 DIY / Maintenance / Service 37 11-15-2013 06:23 AM
DIY for Low Cost Dim Light in the light LED tang DIY / Maintenance / Service 0 03-08-2009 10:58 PM
