Old 08-13-2007, 10:14 AM   #1
Turbo&Auto
Turbo&Auto's Avatar
Drives: 07
afc only tunes af ratio. You need to tune VVT'I and timing as well ;)
Turbo&Auto is offline   Reply With Quote
Old 08-13-2007, 10:26 AM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
Originally Posted by Nabisco View Post
Even better. You will get a print out of what you are putting down to the ground.
Oh I will have the dyno sheet from the tuning of when this is done
I understand the AFC only does the air and fuel, and a VVT controler would be most bennifical..... but no one I know just has a VVT controler just layin around... but I can get ahold of an AFC, if I have good results, then I plan to run it in conjuction with a VVT controller and retune....
I just hope all this shit works cause it would be a fairly inexpensive preformance upgrade
Old 08-13-2007, 10:28 AM   #3
joey1320
joey1320's Avatar
Drives: Yaris LB
exactly.
the afc will only let you lean/rich the fuel mixture by adding/decreasing % values at 6 points on the rpm scale(i think it was 6 )
is the same thing as the simple emanage but the emanage with the support tool gives you a 16 x 16 grid for specific "tuning".
i'm not sure what your friend did but for a n/a vehicle is kind of money wasted. i used the afc twice on civic turbo-homemade kits and it did what it was supposed to but never to the full extend of a true tuning device.
the only way the afc will be of value is if the ecu runs really rich and you can then take some fuel away, then you will see an increase in power but not much really.
good luck man!
joey1320 is offline   Reply With Quote
NEW A'PEXi Exhaust Line up for the 2007+ Toyota Yaris Vic-2NZFE Performance Modifications 13 09-02-2007 06:12 AM
Did anyone installed apexi SAFC ?? jimcat DIY / Maintenance / Service 27 09-02-2007 04:19 AM
Apexi Safc Neo and Toyota Yaris Katana Performance Modifications 2 06-18-2007 08:10 AM
Apex'i I-MONI MC-BPT Sponsors Classifieds Area 0 11-13-2006 03:38 AM
Anyone tried to appy Apexi SAFC or anything similar on their YARIIIII?? oscarying Performance Modifications 25 10-21-2006 09:42 PM
