Old 08-15-2007, 04:21 AM   #1
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
if you want it low, just cut a coil or two off the df's or teins or whatever. the ride will be bouncy and your shocks will die really quickly but you can put your car on the ground if that's what you're after.
reznunt is offline   Reply With Quote
Old 08-15-2007, 09:32 AM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
cut coils do not make you car bouncy, and they do not kill your struts any faster... that is just being dumb.... that is like saying lowering your car is going to kill your struts and make your car bouncy....
Old 08-15-2007, 12:12 PM   #3
AlphaFox
AlphaFox's Avatar
Drives: 07' Yaris Liftback - silver
lowering your call WILL kill your struts faster than if you didnt lower them.
AlphaFox is offline   Reply With Quote
Old 08-15-2007, 05:23 PM   #4
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
obviously you haven't done this before. or maybe you are talking about aftermarket shocks. with oem shocks, first your seals die and leak oil and then you bounce around town. or, if you cut enough coils off and end up sitting on your bumpstops, then when you hit a bump at speed you have no down travel on the shocks which will also make the ride feel "bouncy". he'd be safe with cutting a coil or two, but if he starts bottoming out then the shocks will go soon after. the end.
New 07 Yaris S need advice on 18's and springs OgDogg Wheels, Tires and Suspension Forum sponsored by The Tire Rack 48 04-27-2009 09:50 PM
Minimal Drop From Springs blacksan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 05-15-2007 05:46 AM
Tein Basic Damper Coliey's Vs. Tein S. Tech Springs ToTo Wheels, Tires and Suspension Forum sponsored by The Tire Rack 35 05-07-2007 05:08 PM
Lowering Springs - Questions ~ AGAIN ~ jaspie Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 01-16-2007 12:23 AM
FS: Spirit Lowering Springs 1.7" drop xCookiE Items for Sale by private party 2 07-24-2006 08:29 PM
