Old 08-16-2007, 01:30 PM   #1
jm1681
Janghwa, Hongryeon
jm1681's Avatar
Drives: 20th AE VW GTI
I see your point.
Still, moving a large mass to the rear, and alleviating the front end altogether doesn't seem like a bad proposition.
22B | 藤原とうふ店 | Fatal Frame | 呪怨 | 장화,홍련 | Strong Bad
How to survive a Zombie attack
"The inerasable scars, left by the palms of my hands"
365tuners
jm1681 is offline   Reply With Quote
Old 08-16-2007, 03:13 PM   #2
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
Originally Posted by jm1681 View Post
I see your point.
true, if what you're after is weight distribution. even then, you are moving only 13 lbs (lightweight battery weight) to the rear and distributing the added weight of the cables over the length of the car. this would make more sense if you are moving a stock battery (33 lbs iirc?) from front to rear.
if it is weight savings you want, then just replacing the battery with a race battery is the way to go imo.
reznunt is offline   Reply With Quote
Old 08-16-2007, 03:37 PM   #3
jm1681
Janghwa, Hongryeon
jm1681's Avatar
To each his own I suppose :)
I'm all for adding lightness, and balance in whatever quantities I can. If that means removing 30lbs from the front of the car, adding 15lbs to the back, and maybe 1-2lbs over the length of the car, that works for me ;)
Factoring in the weight of the cables is glaringly good point I never thought of in nearly 7 years of modding cars
365tuners
Old 08-16-2007, 07:58 PM   #4
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
if you use 1/0 welding cable as your power line, 10 feet of it is going to weigh more than two lbs i think. but if you do the relocation, post pics! i did one in my prerunner but opted not to in the yaris. good luck!
lightweight flywheel from fidanza dngz Performance Modifications 34 02-03-2009 11:02 PM
dual batteries or use a cap? punch In Car Entertainment + Electronics (audio / video / alarm) 14 07-17-2007 03:19 AM
anyone know the benifits of lightweight wheels? BrazdonW Wheels, Tires and Suspension Forum sponsored by The Tire Rack 59 07-16-2007 08:22 PM
ZPI Racing Toyota Yaris 06-07 Lightweight Crank Pulley SebYRS Items for Sale by private party 7 06-19-2007 08:00 PM
Toyota plans hybrid that runs on batteries hhcchen Off-topic / Other Cars / Everything else Discussions 2 07-22-2006 01:35 AM
