Old 04-07-2011, 07:42 PM   #1
ecc_33
ecc_33's Avatar
Drives: 2008 toyota yaris
drove 70 miles round trip from home to work than back. Still not as impressed as what i figured it will be. like I said I will change it again at 60,000 and try red line. When I first took off this morning it was about 40* out. It did shift amazing when the car was cold. But after about 10 miles it felt almost as if it was the old fluid. Oh well. It would be nice if it got better after a few more miles. Time will tell.
08 toyota yaris with some big tires lol
02 chevy duramax that runs 11.63 at 116 mph in the 1/4 mile
ecc_33 is offline   Reply With Quote
Old 04-09-2011, 08:05 AM   #2
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Can't see Pics.
Old 07-09-2011, 10:28 PM   #3
ExocetCom
ExocetCom's Avatar
Drives: 2007 Toyota Yaris RS
Brief necro, but wanted to thank the OP for the informative DIY guide. Drained and filled my RS 5MT with Redline MT-90 today and even after only a dozen km of testing, it feels great. Shifts are smoother than on the stock gear oil, and the entire process only took an hour or so.
For those with Tanabe DF-210's installed you can reach both the drain and fill plugs without jacking the car, but it's pretty cramped. I did have to loosen the under-air dam shroud to get good access to the bolts.
Interestingly, I loosened the filler bolt with an air tool and, not knowing that the bolt only had about 3/4" of thread on it, took the entire thing off in one swift go. The result was more than a cup of gear oil spilling out. The two quarts I added after the drain got me right to the proper fill (i.e. right at the bottom of filler plug), but it makes me wonder how I got so much oil in there before.
tl;dr, Redline MT-90 is great so far, process was simple and cheap for DIY, lowered cars can be refilled without jacking, though it is more difficult.
ExocetCom is offline   Reply With Quote
Old 07-13-2011, 08:33 PM   #4
Hard_Yaris
Drives: 07 Yaris
Yes Thanks OP!
Redline MT-90 is the BEST! GL-4 all the way!
Just did another Transmission fluid change.
I found it easier to remove the entire air box to gain access to the fill plug from the top with a funnel and tube.
Hard_Yaris is offline   Reply With Quote
Old 09-03-2011, 01:04 AM   #5
Boyaris
Drives: toyota yaris
Great info. But that only drains 1 3/4 qts. of fluid and there is 4.9 qts. so how do you get the rest out?
Boyaris is offline   Reply With Quote
Old 09-08-2011, 10:57 PM   #6
yaris0128
yaris0128's Avatar
Drives: 07 yaris hatch 95 del sol
Thank you very much for this how to thread sir! Just changed my fluid a few minutes ago and it worked great!
07 yaris LB
95 del sol S
98 civic LX
yaris0128 is offline   Reply With Quote
Old 12-20-2011, 08:48 PM   #7
dan4yaris
Drives: 2007 yaris sedan 4dr
great DIY
Excellent DIY! Just be advised, when you are filling using the vinyl tube with the funnel the oil runs very slow so be patient!
Also, you must use a 24 mm socket, there is some metal on the way when you try to remove the drain bolt. I tried with a wrench it just did not work!
excellent pics to help locate plugs.
drain plug parallel to the drivers tire!
fill plug parallel to the front bumper!
dan4yaris is offline   Reply With Quote
Old 02-14-2012, 03:51 AM   #8
zondakaka
Drives: Yaris Sedan 2006
where can i find a similar guide for the cvt k410 transmission
zondakaka is offline   Reply With Quote
Old 04-08-2012, 06:59 PM   #9
Illryion
Drives: 2007 Yaris Hatchback
Just used this guide - Easy Peasy. Thanks Guys.
Illryion is offline   Reply With Quote
Old 04-09-2012, 01:57 PM   #10
CoryM
Drives: 2009 5-door, 5-speed
A suggestion to all owners, but specifically while doing this job:
Make sure your vent is clear as well. The transmission has a vent on it to allow for the expansion of the oil/air inside. Otherwise the seals have to deal with the pressure and will eventually fail. These vents often clog, and mine was plugged when I got the car with 38000km on it. A good indicator it is plugged is you will hear a hiss of air as you open the fill plug.
I can't recall exactly where the vent is on these cars. iirc it's just behind the shifter. A little white(?) plastic knob that you twist and wiggle a little to free up any junk.
I'll try to find a picture.
Cheers.
Old 04-09-2012, 02:38 PM   #11
CoryM
Pretty sure this is it. Grey metal cap I think.
Old 08-30-2014, 04:17 PM   #12
spookybathtub
Drives: 2007 Yaris HB
Cory, how did you clean the vent? When I removed the filler plug, some air hissed out, so apparently my vent is clogged. From the photo you posted, I can't figure out where it is. Is the vent a bolt, or simply a hole? Can it be cleaned with a squirt of compressed air?
spookybathtub is offline   Reply With Quote
Old 08-31-2014, 12:42 PM   #13
tmontague
tmontague's Avatar
I wouldn't mind knowing where that vent is either. I have changed my trans oil at 87,000km when I got my Yaris but will be doing it again before the winter as I'm at 122,000km and I want to put synthetic in. I didn't hear any air release the first time I did it but I'd like to check it.
Old 09-08-2014, 08:19 PM   #14
donpalino
Drives: Yaris 2010 5Dr MT
Cheers.
Driving a 2010 Hatchback, 5 door, manual with 80K miles
Came back from the dealer after replacing the axle seal, which showed some leaking. Opened the filling cap and heard the hiss so I am sure I have to clean the vent. Now waiting for the MT-90.
Thanks for all the inside info.
donpalino is offline   Reply With Quote
Old 05-16-2012, 06:34 PM   #15
ijose 845
ijose 845's Avatar
Drives: 07 Toyota Yaris
Hey this is a great diy but I'm having difficulty finding the fill plug is it on the bottom front by the airbox or on the side?
Angry Bird Crew #1
ijose 845 is offline   Reply With Quote
Old 05-16-2012, 09:54 PM   #16
Em_
Drives: 2007 Yaris
i did it my self about 2 months ago
it's in the front as you look at the engine
Em_ is offline   Reply With Quote
Old 05-16-2012, 10:25 PM   #17
ijose 845
ijose 845's Avatar
okay thanks! im doing mine tommorow i just wanted to make sure i got everything mapped out before i do it llol
Angry Bird Crew #1
Old 05-16-2012, 11:42 PM   #18
Hershey
You using a torque wrench ? May want to mark one plug as F.P. ( filler plug ) .
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
Yaris Auto need help with tranny oil change chrisada_to2a General Yaris / Vitz Discussion 2 05-17-2007 02:51 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
